Hello,
I have built an Ardomower last year and am very impressed. Fantastic work! I have some further needs (6400 m2 croquet lawn with green quality and a large garden) and am looking into building two mowers:
A) Reel mower for green grass (5 mm) using one John Deere ECut220 reel unit. 48V motors
B) A mower for normal grass but with three mower motors. 24V motors
I am rather new to electronics, but have been coding C# and some C++ for 15 years. Would be very glad for some help. I understand German well, but don’t write so well. I have ordered the BL board and DIY
brushless driver from the shop. I have the PCB 1.3 with Adafruit
M4 and will order the
PCB 1.4 when available.
Brushless questions:
The John Deere cutting unit has a BLDC
motor. See attached schematics. I am not entirely sure of the power, but according to specifications the alternator provides 25-30A depending on version and 48V. I assume 30A as peek power.
1. The specifications (attached) show
motor input A, B, C and hall sensor output C-A, B-C, A-B. All drivers I have seen have U,V,W for both input and hall sensor output. In which order shall C-A, B-C and A-B be connected to a driver?
2. The specification show 12V VCC for the hall sensors. I tried with the ACT Motors 8015A driver (5V) to see if I could get the
motor to rotate without load. I got a little vibration and then the driver burnt. Do I need a driver with 12V hall sensor feed? Where can I find a working driver which can work with the Ardumover BL board?
- Is the BL board using 0-5V or PWM for speed control?
3. I have ordered a few motors for testing and prototyping both mower A (48V 400W with wormgear for driving) and mower B (24V for mower and driver, 50-100W). What do I need to do to use the ACT Motors 8015A (and similar) with the BL board and Ardumower?
4. What is the best way to connect three mower motors to PCB 1.3 (or 1.4) (with BL drive motors also)?
Best,
Anton
