Yes i have this one , i have tried with the power on button and no actionCan you check your version Need : 1.71-AzuritBer-RL1000
Oh it works with aru button ?Yes i have this one , i have tried with the power on button and no action
Où avez-vous connecté ARU sur votre carte PCB1.3
Vérifier:
ARU sur P49
Bouton sur P20
My wiring is ok i have try to change the aru by a button and test but it doesn’t work. i can’t restart mowing or reset alarm with the p20 button sorry now i have a raspberry i can remotly restart it’s better![]()
OK now i understand why it did not work.i have a NO button for start in P20 and a NC button for aru in P49 for info
I have a NO (normally open) button in P20 for startOK now i understand why it did not work.
With raspberry and tactile screen it's perfect.
But P20 button is used to power the PCB1.3 ,so how did you manage this ?
In my config for ROBOMOW the P49 is shunt because it's really easy on RL1000 to remove battery like in initial robomow firmware and P20 button is on the towel to start board after plug the battery.
NO with the french automatic traduct in Google chrome transform in NONSorry i misunderstood ( read no button instead of a NO button ).
Normally the NO P20 button is used to start stop etc.. like describe earlier.
Tested and Work well on my RL2000
I found why the button don’t work.... it’s because i haven’t take to yes « use button » in bumper settings in arduremote... i’m sorry . So the fonction for restart work and is very useful, thank you.Dans arduremote, vous devez être en mode développeur pour avoir accès à ce paramètre.
page d'informations.
Je vérifie le côté pi
