sketch\flashmem.cpp: In member function 'byte* FlashClass::readAddress(uint32_t)':
sketch\flashmem.cpp:79:8: warning: address of local variable 'd' returned [-Wreturn-local-addr]
byte d = readAT24C32(address);
sketch\drivers.cpp:31:69: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char *dayOfWeek[] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
sketch\robot.cpp:68:140: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
"DRIVE2TONEWAREA", "WAITSIG2", "STOPTONEWAREA", "ROLLSTOPTOTRACK", "STOPTOFASTSTART", "CALIBMOTORSPEED", "ACCELFRWRD"};
sketch\robot.cpp:71:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
"SIGWAIT", "WIREMOWING"};
sketch\robot.cpp:73:60: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char *mowPatternNames[] = {"RAND", "LANE", "WIRE", "ZIGZAG"};
sketch\robot.cpp:74:89: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char *consoleModeNames[] = {"sen_counters", "sen_values", "perimeter", "off", "Tracking"};
sketch\robot.cpp: In member function 'virtual void Robot::checkSonar()':
sketch\robot.cpp:4951:37: warning: large integer implicitly truncated to unsigned type [-Woverflow]
setBeeper(2000, 500, 500, 60, 60);
