paddy
Thank you for the pictures.
Regarding disk, I never used the disk from shop because I never had the "old" HDPE Chassis. I startet Ardumower with an old Tianchen chassis, so I re-used everything expect PCB. Tianchen comes with two cutting motors and small blades (like on common gas mowers). The blades were crap, never got them sharp and loud as hell. So I tried to print some kind of disk to be able to attach the common blades from Automower.
Search here in Forum or on Thingiverse (search here for Ardumower) and you'll find my results. I printed them with PETG and use RAMPA thread inserts. They run without any issue for two seasons. I will re-use the discs or even print a larger version for the new chassis.
If you don't trust them because they spin fast, have a look for Automower spare parts. They use different cutting discs (diameter), and don't cost much (15-20€).
Patrick
Patrick
