cat /var/log/syslog | grep 'brcmfmac'
cat /etc/fake-hwclock.data
Maybe you need to check what 's happens on Serial when RTC or NTP change the time/date in the raspian system.I have RTC in Pi now but that not prevent freezes.
You need to set UseMqtt to False if you don't have mosquito broker installed in your home.I found the address inside config.py but I don't understand what it connects to! changing it does not solve the problem? I also tried to ping the address 10.0.0.8 through this site: https://it.infobyip.com/ping-10.0.0.8-ipv4.html
and tells me that he receives nothing
try:
Mqqt_client.username_pw_set( username="admin", password="admin" )
Mqqt_client.connect( host=Mqtt_Broker_IP, port=Mqtt_Port, keepalive=KEEP_ALIVE )
I don't understand this ??Is there an updated version of yaml i used one from azuritber test but it has difference in names.
raspberry/mqtt should look like
Yes .Or should all be on 24/7?
Thanks I'll figure it out with those info.I don't understand this ??
But i need to add everything in the WIKI.ROBOMOW RL1000 Rebuild
Can you check your version Need : 1.71-AzuritBer-RL1000 Yes i have this one , i have tried with the power on button and no actionforum.ardumower.de
Yes .
Actually mower is ON 24/7 and stay into station until AZURITBER timer send a start command or Home Assistant using the Raspberry.
If raspberry is OFF mqtt don't work !! What is your idea ?
