Hi
My Stop Distance / Perimeter setting value is only 8cm because the sensor is in the nose in the front.
And up to now i understand this value as: "The mower will cross the wire max 8cm"
More will be dangerous because then he will hit walls or busches or trees or flowers :S
What do you mean with "strange PID value"?
I just adjusted the max power to 44W now. Lets see...
But good to know have better settings here.
I have done a new IMU compass calib. I started it from PiArdu.
After click on Start PiArdu jumps direct to console and show me the values.
I turned in all directions and then go back to Settings IMU and click again on "Start compass calib" to stop.
Is this right?
This is the LOG:
11:11:49 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 332
11:11:48 .
11:11:48 comScale=853.00,628.00,306.00
11:11:48 COMPASS OFFSET X.Y.Z AND SCALE X.Y.Z --> comOfs=-89.50,-107.00,-268.00
11:11:48 ACCEL GYRO MPU6050 OFFSET ax: -2050 ay: -193 az: 1893 gx: 23 gy: 0 gz: 27
11:11:48 -------- IMU CALIBRATION --------
11:11:48 Calibration address Stop = 650
11:11:48 Calibration address Start = 600
11:11:47 Save Calibration
11:11:47 com calib completed
11:11:03 x:-516.00,337.00 y:-421.00,207.00 z:-421.00,-115.00
11:11:01 x:-472.00,337.00 y:-421.00,207.00 z:-421.00,-128.00
11:11:01 x:-469.00,337.00 y:-421.00,207.00 z:-421.00,-128.00
11:11:01 x:-467.00,337.00 y:-421.00,207.00 z:-421.00,-128.00
11:11:01 x:-461.00,337.00 y:-421.00,207.00 z:-421.00,-128.00
11:10:59 x:-452.00,337.00 y:-421.00,207.00 z:-421.00,-128.00
11:10:58 x:-452.00,337.00 y:-421.00,207.00 z:-420.00,-128.00
11:10:58 x:-452.00,337.00 y:-421.00,207.00 z:-419.00,-128.00
11:10:58 x:-452.00,337.00 y:-421.00,207.00 z:-418.00,-128.00
11:10:58 x:-452.00,337.00 y:-421.00,207.00 z:-414.00,-128.00
11:10:57 x:-452.00,337.00 y:-421.00,207.00 z:-413.00,-128.00
11:10:57 x:-452.00,337.00 y:-421.00,207.00 z:-411.00,-128.00
11:10:47 x:-452.00,337.00 y:-421.00,207.00 z:-407.00,-128.00
11:10:44 x:-452.00,337.00 y:-421.00,187.00 z:-407.00,-128.00
11:10:43 x:-452.00,337.00 y:-409.00,187.00 z:-407.00,-133.00
11:10:39 x:-452.00,169.00 y:-225.00,187.00 z:-407.00,-220.00
11:10:36 x:-318.00,169.00 y:-225.00,187.00 z:-407.00,-344.00
11:10:34 x:-318.00,169.00 y:-225.00,114.00 z:-407.00,-346.00
11:10:34 x:-318.00,169.00 y:-220.00,114.00 z:-407.00,-346.00
11:10:34 x:-318.00,169.00 y:-218.00,114.00 z:-407.00,-346.00
11:10:33 x:-318.00,169.00 y:-167.00,114.00 z:-407.00,-346.00
11:10:32 x:-305.00,169.00 y:-124.00,114.00 z:-407.00,-364.00
11:10:32 x:-300.00,169.00 y:-120.00,114.00 z:-407.00,-370.00
11:10:31 x:-185.00,169.00 y:38.00,114.00 z:-407.00,-390.00
11:10:30 x:-185.00,169.00 y:38.00,114.00 z:-405.00,-390.00
11:10:30 x:-185.00,-177.00 y:103.00,114.00 z:-394.00,-390.00
11:10:29 x:-185.00,-180.00 y:103.00,108.00 z:-394.00,-390.00
11:10:29 x:-185.00,-182.00 y:103.00,106.00 z:-394.00,-390.00
11:10:27 x:-185.00,-183.00 y:103.00,106.00 z:-394.00,-390.00
11:10:26 x:-185.00,-183.00 y:103.00,106.00 z:-393.00,-390.00
11:10:26 x:-185.00,-183.00 y:104.00,106.00 z:-393.00,-390.00
11:10:26 x:-185.00,-183.00 y:104.00,105.00 z:-393.00,-390.00
11:10:25 x:-185.00,-183.00 y:104.00,105.00 z:-393.00,-391.00
11:10:25 x:-184.00,-183.00 y:104.00,105.00 z:-393.00,-391.00
11:10:25 x:-184.00,-183.00 y:104.00,105.00 z:-393.00,-392.00
11:10:25 x:-184.00,-184.00 y:104.00,105.00 z:-393.00,-392.00
11:10:25 x:-184.00,-184.00 y:105.00,105.00 z:-393.00,-393.00
11:10:24 rotate sensor 360 degree around all three axis until NO new data are coming
11:10:24 com calib...
I started mowing with IMU. Started from PiArdu. It takes less then 10min for stopping with errors.
DS1307 comm error
Everytime with IMU i have problems.
Best,
Bjoern
Here is the LOG of last try:
11:24:30 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 449
11:24:30 DS1307 comm error
11:24:29 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:27 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:25 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:24 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:22 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:20 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:19 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:17 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:15 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:13 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:12 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 1785
11:24:11 ERROR / ERR Dir 0 State changed at 912802 From state POUTROLL
11:24:11 Robot Stats address Stop = 826
11:24:11 Robot Stats address Start = 800
11:24:09 Save Robot Stats
11:24:09 DS1307 comm error
11:24:09 NORMALMOWING / POUTROLL Dir 1 State changed at 910839 From state POUTREV
11:24:09 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 744
11:24:07 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 743
11:24:06 NORMALMOWING / POUTREV Dir 1 State changed at 908225 From state POUTSTOP
11:24:05 NORMALMOWING / POUTSTOP Dir 1 State changed at 907385 From state FRWODO
11:24:05 Perimeter trigger at : 907385
11:24:05 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 745
11:24:04 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 744
11:24:02 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 644
11:23:59 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 2420
11:23:54 NORMALMOWING / FRWODO Dir 1 State changed at 896216 From state POUTFOR
11:23:53 NORMALMOWING / POUTFOR Dir 1 State changed at 894668 From state POUTROLL
11:23:50 NORMALMOWING / POUTROLL Dir 1 State changed at 892488 From state POUTREV
11:23:48 NORMALMOWING / POUTREV Dir 1 State changed at 890457 From state POUTSTOP
11:23:48 checktimer
11:23:48 NORMALMOWING / POUTSTOP Dir 1 State changed at 890069 From state FRWODO
11:23:48 Perimeter trigger at : 890069
11:23:44 NORMALMOWING / FRWODO Dir 1 State changed at 886083 From state POUTFOR
11:23:42 NORMALMOWING / POUTFOR Dir 1 State changed at 884557 From state ROLLTOIN
11:23:41 NORMALMOWING / ROLLTOIN Dir 1 State changed at 882634 From state POUTROLL
11:23:41 Find Inside roll nb: 0
11:23:39 NORMALMOWING / POUTROLL Dir 1 State changed at 881252 From state POUTREV
11:23:37 NORMALMOWING / POUTREV Dir 1 State changed at 879371 From state POUTSTOP
11:23:37 NORMALMOWING / POUTSTOP Dir 1 State changed at 878950 From state FRWODO
11:23:37 Perimeter trigger at : 878950
11:23:30 NORMALMOWING / FRWODO Dir 1 State changed at 872544 From state POUTFOR
11:23:29 NORMALMOWING / POUTFOR Dir 1 State changed at 871004 From state POUTROLL
11:23:27 NORMALMOWING / POUTROLL Dir 1 State changed at 869066 From state POUTREV
11:23:25 NORMALMOWING / POUTREV Dir 1 State changed at 867100 From state POUTSTOP
11:23:25 NORMALMOWING / POUTSTOP Dir 1 State changed at 866605 From state FRWODO
11:23:25 Perimeter trigger at : 866605
11:23:24 NORMALMOWING / FRWODO Dir 1 State changed at 865848 From state POUTFOR
11:23:22 NORMALMOWING / POUTFOR Dir 1 State changed at 864335 From state POUTROLL
11:23:20 NORMALMOWING / POUTROLL Dir 1 State changed at 862532 From state POUTREV
11:23:18 NORMALMOWING / POUTREV Dir 1 State changed at 860524 From state POUTSTOP
11:23:18 NORMALMOWING / POUTSTOP Dir 1 State changed at 860097 From state FRWODO
11:23:18 Perimeter trigger at : 860097
11:22:52 NORMALMOWING / FRWODO Dir 1 State changed at 834135 From state POUTFOR
11:22:51 NORMALMOWING / POUTFOR Dir 1 State changed at 832607 From state POUTROLL
11:22:49 NORMALMOWING / POUTROLL Dir 1 State changed at 830800 From state POUTREV
11:22:47 NORMALMOWING / POUTREV Dir 1 State changed at 828863 From state POUTSTOP
11:22:46 checktimer
11:22:46 NORMALMOWING / POUTSTOP Dir 1 State changed at 828392 From state FRWODO
11:22:46 Perimeter trigger at : 828392
11:22:32 NORMALMOWING / FRWODO Dir 1 State changed at 814121 From state POUTFOR
11:22:31 NORMALMOWING / POUTFOR Dir 1 State changed at 812618 From state POUTROLL
11:22:29 NORMALMOWING / POUTROLL Dir 1 State changed at 811465 From state POUTREV
11:22:27 NORMALMOWING / POUTREV Dir 1 State changed at 809524 From state POUTSTOP
11:22:27 NORMALMOWING / POUTSTOP Dir 1 State changed at 809055 From state FRWODO
11:22:27 Perimeter trigger at : 809055
11:22:05 NORMALMOWING / FRWODO Dir 1 State changed at 787343 From state POUTFOR
11:22:04 NORMALMOWING / POUTFOR Dir 1 State changed at 785841 From state POUTROLL
11:22:02 NORMALMOWING / POUTROLL Dir 1 State changed at 784163 From state POUTREV
11:22:00 NORMALMOWING / POUTREV Dir 1 State changed at 782225 From state POUTSTOP
11:22:00 NORMALMOWING / POUTSTOP Dir 1 State changed at 781730 From state FRWODO
11:22:00 Perimeter trigger at : 781730
11:22:00 NORMALMOWING / FRWODO Dir 1 State changed at 781706 From state ROLLTOIN
11:22:00 NORMALMOWING / ROLLTOIN Dir 1 State changed at 781706 From state POUTFOR
11:22:00 Find Inside roll nb: 0
11:21:59 NORMALMOWING / POUTFOR Dir 1 State changed at 780633 From state POUTROLL
11:21:57 NORMALMOWING / POUTROLL Dir 1 State changed at 779464 From state POUTREV
11:21:55 NORMALMOWING / POUTREV Dir 1 State changed at 777542 From state POUTSTOP
11:21:55 NORMALMOWING / POUTSTOP Dir 1 State changed at 777094 From state FRWODO
11:21:55 Perimeter trigger at : 777094
11:21:47 NORMALMOWING / FRWODO Dir 1 State changed at 768806 From state POUTFOR
11:21:45 NORMALMOWING / POUTFOR Dir 1 State changed at 767252 From state POUTROLL
11:21:44 NORMALMOWING / POUTROLL Dir 1 State changed at 765749 From state POUTREV
11:21:42 NORMALMOWING / POUTREV Dir 1 State changed at 763726 From state POUTSTOP
11:21:41 NORMALMOWING / POUTSTOP Dir 1 State changed at 763264 From state FRWODO
11:21:41 Perimeter trigger at : 763264
11:21:41 NORMALMOWING / FRWODO Dir 1 State changed at 762629 From state POUTFOR
11:21:39 NORMALMOWING / POUTFOR Dir 1 State changed at 761092 From state POUTROLL
11:21:38 NORMALMOWING / POUTROLL Dir 1 State changed at 760130 From state POUTREV
11:21:36 NORMALMOWING / POUTREV Dir 1 State changed at 758109 From state POUTSTOP
11:21:36 checktimer
11:21:36 NORMALMOWING / POUTSTOP Dir 1 State changed at 757706 From state FRWODO
11:21:36 Perimeter trigger at : 757706
11:21:25 NORMALMOWING / FRWODO Dir 1 State changed at 746858 From state POUTFOR
11:21:23 NORMALMOWING / POUTFOR Dir 1 State changed at 745371 From state POUTROLL
11:21:23 NORMALMOWING / POUTROLL Dir 1 State changed at 744755 From state POUTREV
11:21:21 NORMALMOWING / POUTREV Dir 1 State changed at 742814 From state POUTSTOP
11:21:20 NORMALMOWING / POUTSTOP Dir 1 State changed at 742347 From state FRWODO
11:21:20 Perimeter trigger at : 742347
11:21:20 NORMALMOWING / FRWODO Dir 1 State changed at 741663 From state POUTFOR
11:21:18 NORMALMOWING / POUTFOR Dir 1 State changed at 740100 From state POUTROLL
11:21:18 NORMALMOWING / POUTROLL Dir 1 State changed at 739634 From state POUTREV
11:21:16 NORMALMOWING / POUTREV Dir 1 State changed at 737740 From state POUTSTOP
11:21:15 NORMALMOWING / POUTSTOP Dir 1 State changed at 737277 From state FRWODO
11:21:15 Perimeter trigger at : 737277
11:20:50 NORMALMOWING / FRWODO Dir 1 State changed at 711945 From state POUTFOR
11:20:48 NORMALMOWING / POUTFOR Dir 1 State changed at 710400 From state POUTROLL
11:20:47 NORMALMOWING / POUTROLL Dir 1 State changed at 709219 From state POUTREV
11:20:45 NORMALMOWING / POUTREV Dir 1 State changed at 707252 From state POUTSTOP
11:20:45 NORMALMOWING / POUTSTOP Dir 1 State changed at 706791 From state FRWODO
11:20:45 Perimeter trigger at : 706791
11:20:44 NORMALMOWING / FRWODO Dir 1 State changed at 705835 From state POUTFOR
11:20:42 NORMALMOWING / POUTFOR Dir 1 State changed at 704306 From state POUTROLL
11:20:41 NORMALMOWING / POUTROLL Dir 1 State changed at 703291 From state POUTREV
11:20:39 NORMALMOWING / POUTREV Dir 1 State changed at 701272 From state POUTSTOP
11:20:39 NORMALMOWING / POUTSTOP Dir 1 State changed at 700851 From state FRWODO
11:20:39 Perimeter trigger at : 700851
11:20:26 NORMALMOWING / FRWODO Dir 1 State changed at 688432 From state POUTFOR
11:20:25 NORMALMOWING / POUTFOR Dir 1 State changed at 686939 From state POUTROLL
11:20:24 NORMALMOWING / POUTROLL Dir 1 State changed at 686308 From state POUTREV
11:20:22 NORMALMOWING / POUTREV Dir 1 State changed at 684281 From state POUTSTOP
11:20:22 checktimer
11:20:22 NORMALMOWING / POUTSTOP Dir 1 State changed at 683720 From state FRWODO
11:20:22 Perimeter trigger at : 683720
11:20:06 NORMALMOWING / FRWODO Dir 1 State changed at 668466 From state POUTFOR
11:20:05 NORMALMOWING / POUTFOR Dir 1 State changed at 666939 From state POUTROLL
11:20:03 NORMALMOWING / POUTROLL Dir 1 State changed at 664871 From state POUTREV
11:20:01 NORMALMOWING / POUTREV Dir 1 State changed at 662928 From state POUTSTOP
11:20:00 NORMALMOWING / POUTSTOP Dir 1 State changed at 662503 From state FRWODO
11:20:00 Perimeter trigger at : 662502
11:19:40 NORMALMOWING / FRWODO Dir 1 State changed at 642176 From state POUTFOR
11:19:39 NORMALMOWING / POUTFOR Dir 1 State changed at 640613 From state POUTROLL
11:19:37 NORMALMOWING / POUTROLL Dir 1 State changed at 638792 From state POUTREV
11:19:35 NORMALMOWING / POUTREV Dir 1 State changed at 636738 From state POUTSTOP
11:19:34 NORMALMOWING / POUTSTOP Dir 1 State changed at 636280 From state FRWODO
11:19:34 Perimeter trigger at : 636280
11:19:23 NORMALMOWING / FRWODO Dir 1 State changed at 625201 From state POUTFOR
11:19:22 NORMALMOWING / POUTFOR Dir 1 State changed at 623737 From state POUTROLL
11:19:20 NORMALMOWING / POUTROLL Dir 1 State changed at 621868 From state POUTREV
11:19:18 NORMALMOWING / POUTREV Dir 1 State changed at 619989 From state POUTSTOP
11:19:17 checktimer
11:19:17 NORMALMOWING / POUTSTOP Dir 1 State changed at 619349 From state FRWODO
11:19:17 Perimeter trigger at : 619349
11:19:04 NORMALMOWING / FRWODO Dir 1 State changed at 605930 From state POUTFOR
11:19:02 NORMALMOWING / POUTFOR Dir 1 State changed at 604389 From state POUTROLL
11:19:01 NORMALMOWING / POUTROLL Dir 1 State changed at 603454 From state POUTREV
11:18:59 NORMALMOWING / POUTREV Dir 1 State changed at 601486 From state POUTSTOP
11:18:59 NORMALMOWING / POUTSTOP Dir 1 State changed at 601041 From state FRWODO
11:18:59 Perimeter trigger at : 601041
11:18:55 NORMALMOWING / FRWODO Dir 1 State changed at 597557 From state POUTFOR
11:18:54 NORMALMOWING / POUTFOR Dir 1 State changed at 596026 From state POUTROLL
11:18:53 NORMALMOWING / POUTROLL Dir 1 State changed at 594953 From state POUTREV
11:18:51 NORMALMOWING / POUTREV Dir 1 State changed at 592973 From state POUTSTOP
11:18:50 NORMALMOWING / POUTSTOP Dir 1 State changed at 592516 From state FRWODO
11:18:50 Perimeter trigger at : 592516
11:18:41 NORMALMOWING / FRWODO Dir 1 State changed at 582687 From state POUTFOR
11:18:39 NORMALMOWING / POUTFOR Dir 1 State changed at 581151 From state POUTROLL
11:18:38 NORMALMOWING / POUTROLL Dir 1 State changed at 579909 From state POUTREV
11:18:36 NORMALMOWING / POUTREV Dir 1 State changed at 577987 From state POUTSTOP
11:18:35 NORMALMOWING / POUTSTOP Dir 1 State changed at 577486 From state FRWODO
11:18:35 Perimeter trigger at : 577486
11:18:35 NORMALMOWING / FRWODO Dir 1 State changed at 577464 From state ROLLTOIN
11:18:35 NORMALMOWING / ROLLTOIN Dir 1 State changed at 577464 From state POUTFOR
11:18:35 Find Inside roll nb: 0
11:18:34 NORMALMOWING / POUTFOR Dir 1 State changed at 575931 From state POUTROLL
11:18:33 NORMALMOWING / POUTROLL Dir 1 State changed at 575330 From state POUTREV
11:18:31 NORMALMOWING / POUTREV Dir 1 State changed at 573483 From state POUTSTOP
11:18:31 NORMALMOWING / POUTSTOP Dir 1 State changed at 572852 From state FRWODO
11:18:31 Perimeter trigger at : 572852
11:18:20 NORMALMOWING / FRWODO Dir 1 State changed at 561946 From state POUTFOR
11:18:18 NORMALMOWING / POUTFOR Dir 1 State changed at 560413 From state POUTROLL
11:18:17 NORMALMOWING / POUTROLL Dir 1 State changed at 559238 From state POUTREV
11:18:15 NORMALMOWING / POUTREV Dir 1 State changed at 557273 From state POUTSTOP
11:18:15 checktimer
11:18:15 NORMALMOWING / POUTSTOP Dir 1 State changed at 556824 From state FRWODO
11:18:15 Perimeter trigger at : 556824
11:18:12 NORMALMOWING / FRWODO Dir 1 State changed at 553679 From state POUTFOR
11:18:10 NORMALMOWING / POUTFOR Dir 1 State changed at 552150 From state POUTROLL
11:18:09 NORMALMOWING / POUTROLL Dir 1 State changed at 551444 From state POUTREV
11:18:07 NORMALMOWING / POUTREV Dir 1 State changed at 549401 From state POUTSTOP
11:18:07 NORMALMOWING / POUTSTOP Dir 1 State changed at 548954 From state FRWODO
11:18:07 Perimeter trigger at : 548954
11:18:02 NORMALMOWING / FRWODO Dir 1 State changed at 543668 From state POUTFOR
11:18:00 NORMALMOWING / POUTFOR Dir 1 State changed at 542127 From state POUTROLL
11:17:59 NORMALMOWING / POUTROLL Dir 1 State changed at 540759 From state POUTREV
11:17:57 NORMALMOWING / POUTREV Dir 1 State changed at 538798 From state POUTSTOP
11:17:56 NORMALMOWING / POUTSTOP Dir 1 State changed at 538313 From state FRWODO
11:17:56 Perimeter trigger at : 538313
11:17:47 NORMALMOWING / FRWODO Dir 1 State changed at 529142 From state POUTFOR
11:17:45 NORMALMOWING / POUTFOR Dir 1 State changed at 527579 From state POUTROLL
11:17:43 NORMALMOWING / POUTROLL Dir 1 State changed at 525566 From state POUTREV
11:17:42 NORMALMOWING / POUTREV Dir 1 State changed at 523641 From state POUTSTOP
11:17:41 NORMALMOWING / POUTSTOP Dir 1 State changed at 523181 From state FRWODO
11:17:41 Perimeter trigger at : 523181
11:17:35 NORMALMOWING / FRWODO Dir 1 State changed at 517379 From state POUTFOR
11:17:34 NORMALMOWING / POUTFOR Dir 1 State changed at 515852 From state POUTROLL
11:17:32 NORMALMOWING / POUTROLL Dir 1 State changed at 514590 From state POUTREV
11:17:31 NORMALMOWING / POUTREV Dir 1 State changed at 512651 From state POUTSTOP
11:17:30 NORMALMOWING / POUTSTOP Dir 1 State changed at 512249 From state FRWODO
11:17:30 Perimeter trigger at : 512249
11:17:20 NORMALMOWING / FRWODO Dir 1 State changed at 502215 From state POUTFOR
11:17:19 NORMALMOWING / POUTFOR Dir 1 State changed at 500699 From state POUTROLL
11:17:17 NORMALMOWING / POUTROLL Dir 1 State changed at 498855 From state POUTREV
11:17:15 NORMALMOWING / POUTREV Dir 1 State changed at 496843 From state POUTSTOP
11:17:14 checktimer
11:17:14 NORMALMOWING / POUTSTOP Dir 1 State changed at 496409 From state FRWODO
11:17:14 Perimeter trigger at : 496409
11:17:12 NORMALMOWING / FRWODO Dir 1 State changed at 494095 From state POUTFOR
11:17:10 NORMALMOWING / POUTFOR Dir 1 State changed at 492529 From state POUTROLL
11:17:10 NORMALMOWING / POUTROLL Dir 1 State changed at 491985 From state POUTREV
11:17:08 NORMALMOWING / POUTREV Dir 1 State changed at 490066 From state POUTSTOP
11:17:07 NORMALMOWING / POUTSTOP Dir 1 State changed at 489530 From state FRWODO
11:17:07 Perimeter trigger at : 489530
11:16:59 NORMALMOWING / FRWODO Dir 1 State changed at 480805 From state POUTFOR
11:16:57 NORMALMOWING / POUTFOR Dir 1 State changed at 479255 From state POUTROLL
11:16:55 NORMALMOWING / POUTROLL Dir 1 State changed at 476994 From state POUTREV
11:16:53 NORMALMOWING / POUTREV Dir 1 State changed at 475002 From state POUTSTOP
11:16:52 NORMALMOWING / POUTSTOP Dir 1 State changed at 474520 From state FRWODO
11:16:52 Perimeter trigger at : 474520
11:16:46 NORMALMOWING / FRWODO Dir 1 State changed at 468493 From state POUTFOR
11:16:45 NORMALMOWING / POUTFOR Dir 1 State changed at 466945 From state POUTROLL
11:16:43 NORMALMOWING / POUTROLL Dir 1 State changed at 465259 From state POUTREV
11:16:41 NORMALMOWING / POUTREV Dir 1 State changed at 463315 From state POUTSTOP
11:16:41 NORMALMOWING / POUTSTOP Dir 1 State changed at 462852 From state FRWODO
11:16:41 Perimeter trigger at : 462852
11:16:31 NORMALMOWING / FRWODO Dir 1 State changed at 453562 From state POUTFOR
11:16:30 NORMALMOWING / POUTFOR Dir 1 State changed at 452005 From state POUTROLL
11:16:29 NORMALMOWING / POUTROLL Dir 1 State changed at 450750 From state POUTREV
11:16:27 NORMALMOWING / POUTREV Dir 1 State changed at 448870 From state POUTSTOP
11:16:26 NORMALMOWING / POUTSTOP Dir 1 State changed at 448362 From state FRWODO
11:16:26 Perimeter trigger at : 448362
11:16:22 NORMALMOWING / FRWODO Dir 1 State changed at 444122 From state POUTFOR
11:16:21 NORMALMOWING / POUTFOR Dir 1 State changed at 442620 From state POUTROLL
11:16:20 NORMALMOWING / POUTROLL Dir 1 State changed at 441778 From state POUTREV
11:16:18 NORMALMOWING / POUTREV Dir 1 State changed at 439815 From state POUTSTOP
11:16:17 NORMALMOWING / POUTSTOP Dir 1 State changed at 439383 From state FRWODO
11:16:17 Perimeter trigger at : 439383
11:16:17 NORMALMOWING / FRWODO Dir 1 State changed at 438903 From state POUTFOR
11:16:15 NORMALMOWING / POUTFOR Dir 1 State changed at 437395 From state POUTROLL
11:16:14 NORMALMOWING / POUTROLL Dir 1 State changed at 435907 From state POUTREV
11:16:12 NORMALMOWING / POUTREV Dir 1 State changed at 433988 From state POUTSTOP
11:16:11 checktimer
11:16:11 NORMALMOWING / POUTSTOP Dir 1 State changed at 433509 From state FRWODO
11:16:11 Perimeter trigger at : 433509
11:16:08 NORMALMOWING / FRWODO Dir 1 State changed at 429670 From state POUTFOR
11:16:06 NORMALMOWING / POUTFOR Dir 1 State changed at 428128 From state POUTROLL
11:16:04 NORMALMOWING / POUTROLL Dir 1 State changed at 426287 From state POUTREV
11:16:02 NORMALMOWING / POUTREV Dir 1 State changed at 424410 From state POUTSTOP
11:16:02 NORMALMOWING / POUTSTOP Dir 1 State changed at 423945 From state FRWODO
11:16:02 Perimeter trigger at : 423945
11:16:00 NORMALMOWING / FRWODO Dir 1 State changed at 422299 From state POUTFOR
11:15:59 NORMALMOWING / POUTFOR Dir 1 State changed at 420751 From state POUTROLL
11:15:57 NORMALMOWING / POUTROLL Dir 1 State changed at 418895 From state POUTREV
11:15:55 NORMALMOWING / POUTREV Dir 1 State changed at 416980 From state POUTSTOP
11:15:54 NORMALMOWING / POUTSTOP Dir 1 State changed at 416397 From state FRWODO
11:15:54 Perimeter trigger at : 416397
11:15:54 NORMALMOWING / FRWODO Dir 1 State changed at 416378 From state ROLLTOIN
11:15:54 NORMALMOWING / ROLLTOIN Dir 1 State changed at 416378 From state POUTFOR
11:15:54 Find Inside roll nb: 0
11:15:54 NORMALMOWING / POUTFOR Dir 1 State changed at 415943 From state POUTROLL
11:15:52 NORMALMOWING / POUTROLL Dir 1 State changed at 414592 From state POUTREV
11:15:51 NORMALMOWING / POUTREV Dir 1 State changed at 412754 From state POUTSTOP
11:15:50 NORMALMOWING / POUTSTOP Dir 1 State changed at 412277 From state FRWODO
11:15:50 Perimeter trigger at : 412277
11:15:24 NORMALMOWING / FRWODO Dir 1 State changed at 386212 From state AUTOCALIB
11:15:24 Calib OK next state out rev
11:15:24 4 sec of read value, verify if the drift is stop
11:15:20 NORMALMOWING / AUTOCALIB Dir 1 State changed at 381660 From state STOPCALIB
11:15:19 NORMALMOWING / STOPCALIB Dir 1 State changed at 381497 From state ROLLTOFINDYAW
11:15:17 NORMALMOWING / ROLLTOFINDYAW Dir 1 State changed at 379303 From state FINDYAWSTOP
11:15:17 >>> >>> >>> >>> >>> >>> 0
11:15:17 imu.comYaw 100.18 imu.ypr.yaw 186.13 distancePI(imu.comYaw, imu.ypr.yaw) 0.86
11:15:17 NORMALMOWING / FINDYAWSTOP Dir 1 State changed at 378679 From state FRWODO
11:15:13 NORMALMOWING / FRWODO Dir 1 State changed at 374678 From state POUTFOR
11:15:11 NORMALMOWING / POUTFOR Dir 1 State changed at 373127 From state POUTROLL
11:15:10 NORMALMOWING / POUTROLL Dir 1 State changed at 371625 From state POUTREV
11:15:08 NORMALMOWING / POUTREV Dir 1 State changed at 369672 From state POUTSTOP
11:15:07 NORMALMOWING / POUTSTOP Dir 1 State changed at 369229 From state FRWODO
11:15:07 Perimeter trigger at : 369228
11:15:07 NORMALMOWING / FRWODO Dir 1 State changed at 369208 From state ROLLTOIN
11:15:07 NORMALMOWING / ROLLTOIN Dir 1 State changed at 369208 From state POUTFOR
11:15:07 Find Inside roll nb: 0
11:15:07 NORMALMOWING / POUTFOR Dir 1 State changed at 368918 From state POUTROLL
11:15:06 NORMALMOWING / POUTROLL Dir 1 State changed at 368317 From state POUTREV
11:15:04 NORMALMOWING / POUTREV Dir 1 State changed at 366337 From state POUTSTOP
11:15:04 checktimer
11:15:04 NORMALMOWING / POUTSTOP Dir 1 State changed at 365947 From state FRWODO
11:15:04 Perimeter trigger at : 365947
11:14:39 341239 Rotation direction Left / Right change
11:14:39 NORMALMOWING / FRWODO Dir 0 State changed at 341169 From state OFF
Best,
Bjoern
