The main issue is that i Don't have
motor from shop ,so i can't give you the perfect value for your platform,Maybe Jussip can share them.
All these setting help to have smooth movement.
For point 1: What is the target? To find the slowest possible speed?
Yes just a little more than the slowest possible.
If mower can't move at Pwm=50 and just a little at PWM=60, you can set 70 for example.
You can see the result when mower reach the wire on normal mowing the
motor brake and change direction.
If the value is OK, all is smooth , if too high it's not smooth (hard brake),if too low the mower stop for some secondes and you can see this kind of message into console ("Warning can t peri out stop in time ")
What is the idea behind point 2
You need to find the PWM that is the best for you when mower run at logical speed.
The mower use RPM and PWM to control
motor so both need to be correctly set, or in manual mode for example when you click on right the
motor can change dir only 1 seconde later and same for stop.
When click on stop the
motor need to stop immediatly.
For point 5 i have nothing in console
It's not normal at all and same for INCOMMING MESSAGE ERROR FROM DUE
There is a big issue with the Pi setting.
Into mower.h
line 132 and 133 need to be
uncommented
line 129 and 130 need to be
commented
if you want that the PI receive the console message.
Into Arduremote Into setting R/C the Use Rasberry(Need Reboot) need to be YES and Use RC to NO
In moment my console is full with "checktimer"
Normal if mower is into station.
and clicked on "Add This Tag".
You have to do this exactly in the opposite order.
Click on the list so the value are update on the right textBox.
Click on Delete this Tag.
Change value on the textBox
And click on add this Tag.
Do not click on ADD before DELETE
Save to file.
The result was that both Tags are deleted.
Normal ,You can't have same TagNr with same STATUS or both are delete
Is it the tag_list.bin? This format is not easy to debug.
Yes it's binary file and no need debug simply try again on the RFID page .
i added the Tag manual new
The tagNr need to be exact ,simply copy it from console and past value without space before or after
Actualy The Status list can contain only one of these value (BACK_TO_STATION, TRACK_TO_START,WIRE_MOWING) without space before or after
Actualy The What to do list can contain only one of these value (FAST_START,RTS,SPEED,NEW_AREA) without space before or after
For all you certainly have a problem with the PI Setting
Can you go into Pi console, Start a 5 minutes mowing trip, click on save and show me the 3 files (There are in the log directory,sort them by date to find easily)
Before or After the INCOMMING MESSAGE ERROR FROM DUE you have the message , What is it exactly.
Do you have access to python idle? to show me the shell start of the Piardu to be sure all is OK.
