Hallo Uwe,
es ist ein LiFePo Akku und die Spannung ist nachgemessen über 12,3 V. Software ist 1.0a2. Platine V1.2. ADC Kalibrierung durchgeführt. Lötstelle kann ich ausschließen. Serielle Konsole kann ich eventuell morgen aufzeichnen.
Gruß Andreas
Hier die mower.cpp:
Ardumower (www.ardumower.de)
Copyright (c) 2013-2015 by Alexander Grau
Copyright (c) 2013-2015 by Sven Gennat
Copyright (c) 2014 by Maxime Carpentieri
Copyright (c) 2014-2015 by Stefan Manteuffel
Copyright (c) 2015 by Uwe Zimprich
Private-use only! (you need to ask for a commercial-use)
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see .
/* Ardumower Chassis Kit 1.0 - robot configuration (Ardumower electronics,
Arduino Mega)
http://wiki.ardumower.de/index.php?title=Ardumower_chassis
Requires: Ardumower PCB v0.5 (
https://www.marotronics.de/Ardumower-Board-Prototyp )
// NOTE: Verify in config.h that you have enabled 'USE_MOWER' !
#include "config.h"
#ifdef USE_MOWER
#include
#include "mower.h"
#include "due.h"
// ------ pins---------------------------------------
#define pinMotorEnable 37 // EN motors enable
#define pinMotorLeftPWM 5 // M1_IN1 left
motor PWM pin
#define pinMotorLeftDir 31 // M1_IN2 left
motor Dir pin
#define pinMotorLeftSense A1 // M1_FB left
motor current sense
#define pinMotorLeftFault 25 // M1_SF left
motor fault
#define pinMotorRightPWM 3 // M2_IN1 right
motor PWM pin
#define pinMotorRightDir 33 // M2_IN2 right
motor Dir pin
#define pinMotorRightSense A0 // M2_FB right
motor current sense
#define pinMotorRightFault 27 // M2_SF right
motor fault
#define pinMotorMowPWM 2 // M1_IN1 mower
motor PWM pin (if using MOSFET, use this pin)
#define pinMotorMowDir 29 // M1_IN2 mower
motor Dir pin (if using MOSFET, keep unconnected)
#define pinMotorMowSense A3 // M1_FB mower
motor current sense
#define pinMotorMowFault 26 // M1_SF mower
motor fault (if using MOSFET/L298N, keep unconnected)
#define pinMotorMowEnable 28 // EN mower
motor enable (if using MOSFET/L298N, keep unconnected)
#define pinMotorMowRpm A11
#define pinBumperLeft 39 // bumper pins
#define pinBumperRight 38
#define pinDropLeft 45 // drop pins Dropsensor - Absturzsensor
#define pinDropRight 23 // drop pins Dropsensor - Absturzsensor
#define pinSonarCenterTrigger 24 // ultrasonic sensor pins
#define pinSonarCenterEcho 22
#define pinSonarRightTrigger 30
#define pinSonarRightEcho 32
#define pinSonarLeftTrigger 34
#define pinSonarLeftEcho 36
#define pinPerimeterRight A4 // perimeter
#define pinPerimeterLeft A5
#define pinLED 13 // LED
#define pinBuzzer 53 // Buzzer
#define pinTilt 35 // Tilt sensor (required for TC-G158 board)
#define pinButton 51 // digital ON/OFF button
#define pinBatteryVoltage A2 // battery voltage sensor
#define pinBatterySwitch 4 // battery-OFF switch
#define pinChargeVoltage A9 // charging voltage sensor
#define pinChargeCurrent A8 // charge current sensor
#define pinChargeRelay 50 // charge relay
#define pinRemoteMow 12 // remote control mower
motor
#define pinRemoteSteer 11 // remote control steering
#define pinRemoteSpeed 10 // remote control speed
#define pinRemoteSwitch 52 // remote control switch
#define pinVoltageMeasurement A7 // test pin for your own voltage measurements
#ifdef __AVR__
#define pinOdometryLeft A12 // left odometry sensor
#define pinOdometryLeft2 A13 // left odometry sensor (optional two-wire)
#define pinOdometryRight A14 // right odometry sensor
#define pinOdometryRight2 A15 // right odometry sensor (optional two-wire)
#else
#define pinOdometryLeft DAC0 // left odometry sensor
#define pinOdometryLeft2 DAC1 // left odometry sensor (optional two-wire)
#define pinOdometryRight CANRX // right odometry sensor
#define pinOdometryRight2 CANTX // right odometry sensor (optional two-wire)
#endif
#define pinLawnFrontRecv 40 // lawn sensor front receive
#define pinLawnFrontSend 41 // lawn sensor front sender
#define pinLawnBackRecv 42 // lawn sensor back receive
#define pinLawnBackSend 43 // lawn sensor back sender
#define pinUserSwitch1 46 // user-defined switch 1
#define pinUserSwitch2 47 // user-defined switch 2
#define pinUserSwitch3 48 // user-defined switch 3
#define pinRain 44 // rain sensor
// IMU (compass/gyro/accel): I2C (SCL, SDA)
// Bluetooth: Serial2 (TX2, RX2)
// GPS: Serial3 (TX3, RX3)
// ------- baudrates---------------------------------
#define BAUDRATE 19200 // serial output baud rate
#define PFOD_BAUDRATE 19200 // pfod app serial output baud rate
#define PFOD_PIN 1234 // Bluetooth pin
//#define USE_DEVELOPER_TEST 1 // uncomment for new perimeter signal test (developers)
Mower robot;
Mower::Mower(){
name = "Ardumower";
// ------- wheel motors -----------------------------
motorAccel = 500; //
motor wheel acceleration - only functional when odometry is not in use (warning: do not set too low)
motorSpeedMaxRpm = 25; //
motor wheel max RPM (WARNING: do not set too high, so there's still speed control when battery is low!)
motorSpeedMaxPwm = 255; //
motor wheel max Pwm (8-bit PWM=255, 10-bit PWM=1023)
motorPowerMax = 75; //
motor wheel max power (Watt)
motorSenseRightScale = 15.3; //
motor right sense scale (mA=(ADC-zero)/scale)
motorSenseLeftScale = 15.3; //
motor left sense scale (mA=(ADC-zero)/scale)
motorPowerIgnoreTime = 2000; // time to ignore
motor power (ms)
motorZeroSettleTime = 2000 ; // how long (ms) to wait for motors to settle at zero speed
motorRollTimeMax = 3000; // max. roll time (ms)
motorReverseTime = 3500; // max. reverse time (ms)
motorForwTimeMax = 60000; // max. forward time (ms) / timeout
motorBiDirSpeedRatio1 = 0.3; // bidir mow pattern speed ratio 1
motorBiDirSpeedRatio2 = 0.92; // bidir mow pattern speed ratio 2
// ---- normal control ---
motorLeftPID.Kp = 0.87; //
motor wheel PID controller
motorLeftPID.Ki = 0.29;
motorLeftPID.Kd = 0.25;
/*// ---- fast control ---
motorLeftPID.Kp = 1.76; //
motorLeftPID.Ki = 0.87;
motorLeftPID.Kd = 0.4;*/
motorRightSwapDir = 0; // inverse right
motor direction?
motorLeftSwapDir = 1; // inverse left
motor direction?
// ------ mower
motor -------------------------------
motorMowAccel = 0.1; //
motor mower acceleration (warning: do not set too high)
motorMowSpeedMaxPwm = 255; //
motor mower max PWM
motorMowPowerMax = 75.0; //
motor mower max power (Watt)
motorMowModulate = 0; //
motor mower cutter modulation?
motorMowRPMSet = 3300; //
motor mower RPM (only for cutter modulation)
motorMowSenseScale = 15.3; //
motor mower sense scale (mA=(ADC-zero)/scale)
motorMowPID.Kp = 0.005; //
motor mower RPM PID controller
motorMowPID.Ki = 0.01;
motorMowPID.Kd = 0.01;
// ------ bumper -----------------------------------
bumperUse = 1; // has bumpers?
// ------ drop -----------------------------------
dropUse = 0; // has drops? Dropsensor - Absturzsensor vorhanden ?
dropcontact = 1; //contact 0-openers 1-closers Dropsensor - Kontakt 0-Öffner - 1-Schließer betätigt gegen GND
// ------ rain ------------------------------------
rainUse = 0; // use rain sensor?
// ------ sonar ------------------------------------
sonarUse = 1; // use ultra sonic sensor? (WARNING: robot will slow down, if enabled but not connected!)
sonarLeftUse = 0;
sonarRightUse = 0;
sonarCenterUse = 1;
sonarTriggerBelow = 900; // ultrasonic sensor trigger distance
// ------ perimeter ---------------------------------
perimeterUse = 1; // use perimeter?
perimeterTriggerTimeout = 0; // perimeter trigger timeout when escaping from inside (ms)
perimeterTrackRollTime = 3000; // perimter tracking roll time (ms)
perimeterTrackRevTime = 2000; // perimter tracking reverse time (ms)
perimeterPID.Kp = 51.0; // perimeter PID controller
perimeterPID.Ki = 12.5;
perimeterPID.Kd = 0.8;
trackingPerimeterTransitionTimeOut = 2000;
trackingErrorTimeOut = 10000;
trackingBlockInnerWheelWhilePerimeterStruggling = 1;
// ------ lawn sensor --------------------------------
lawnSensorUse = 0; // use capacitive Sensor
// ------ IMU (compass/accel/gyro) ----------------------
imuUse = 0; // use IMU?
imuCorrectDir = 0; // correct direction by compass?
imuDirPID.Kp = 5.0; // direction PID controller
imuDirPID.Ki = 1.0;
imuDirPID.Kd = 1.0;
imuRollPID.Kp = 0.8; // roll PID controller
imuRollPID.Ki = 21;
imuRollPID.Kd = 0;
// ------ model R/C ------------------------------------
remoteUse = 0; // use model remote control (R/C)?
// ------ battery -------------------------------------
batMonitor = 1; // monitor battery and charge voltage?
batGoHomeIfBelow = 10.5; // drive home voltage (Volt)
batSwitchOffIfBelow = 9.0; // switch off battery if below voltage (Volt)
batSwitchOffIfIdle = 1; // switch off battery if idle (minutes)
batFactor = 0.2099; // battery conversion factor / 10 due to arduremote bug, can be removed after fixing (look in robot.cpp)
batChgFactor = 0.2099; // battery conversion factor / 10 due to arduremote bug, can be removed after fixing (look in robot.cpp)
batFull =12.4; // battery reference Voltage (fully charged) PLEASE ADJUST IF USING A DIFFERENT BATTERY VOLTAGE! FOR a 12V SYSTEM TO 14.4V
batChargingCurrentMax =1.6; // maximum current your charger can devliver
batFullCurrent = 0.3; // current flowing when battery is fully charged
startChargingIfBelow = 9.0; // start charging if battery Voltage is below
chargingTimeout = 12600000; // safety timer for charging (ms) 12600000 = 3.5hrs
// Sensorausgabe Konsole (chgSelection =0)
// Einstellungen ACS712 5A (chgSelection =1 / chgSenseZero ~ 511 / chgFactor = 39 / chgSense =185.0 / chgChange = 0 oder 1 (je nach Stromrichtung) / chgNull = 2)
// Einstellungen INA169 board (chgSelection =2)
chgSelection = 2;
chgSenseZero = 511; // charge current sense zero point
chgFactor = 39; // charge current conversion factor - Empfindlichkeit nimmt mit ca. 39/V Vcc ab
chgSense = 185.0; // mV/A empfindlichkeit des Ladestromsensors in mV/A (Für ACS712 5A = 185)
chgChange = 0; // Messwertumkehr von - nach + 1 oder 0
chgNull = 2; // Nullduchgang abziehen (1 oder 2)
// ------ charging station ---------------------------
stationRevTime = 4000; // charge station reverse time (ms)
stationRollTime = 2000; // charge station roll time (ms)
stationForwTime = 2000; // charge station forward time (ms)
stationCheckTime = 2500; // charge station reverse check time (ms)
// ------ odometry ------------------------------------
odometryUse = 0; // use odometry?
twoWayOdometrySensorUse = 1; // use optional two-wire odometry sensor?
odometryTicksPerRevolution = 1060; // encoder ticks per one full resolution
odometryTicksPerCm = 13.49; // encoder ticks per cm
odometryWheelBaseCm = 36; // wheel-to-wheel distance (cm)
odometryRightSwapDir = 0; // inverse right encoder direction?
odometryLeftSwapDir = 1; // inverse left encoder direction?
// ----- GPS -------------------------------------------
gpsUse = 0; // use GPS?
// ----- other -----------------------------------------
buttonUse = 1; // has digital ON/OFF button?
// ----- user-defined switch ---------------------------
userSwitch1 = 0; // user-defined switch 1 (default value)
userSwitch2 = 0; // user-defined switch 2 (default value)
userSwitch3 = 0; // user-defined switch 3 (default value)
// ----- timer -----------------------------------------
timerUse = 0; // use RTC and timer?
// ------ configuration end -------------------------------------------
// remote control (RC) ppm signal change interrupt
ISR(PCINT0_vect){
unsigned long timeMicros = micros();
boolean remoteSpeedState = digitalRead(pinRemoteSpeed);
boolean remoteSteerState = digitalRead(pinRemoteSteer);
boolean remoteMowState = digitalRead(pinRemoteMow);
boolean remoteSwitchState = digitalRead(pinRemoteSwitch);
robot.setRemotePPMState(timeMicros, remoteSpeedState, remoteSteerState, remoteMowState, remoteSwitchState);
// odometry signal change interrupt
// mower
motor speed sensor interrupt
// NOTE: when choosing a higher perimeter sample rate (38 kHz) and using odometry interrupts,
// the
Arduino Mega cannot handle all ADC interrupts anymore - the result will be a 'noisy'
// perimeter filter output (mag value) which disappears when disabling odometry interrupts.
// SOLUTION: allow odometry interrupt handler nesting (see odometry interrupt function)
http://www.nongnu.org/avr-libc/user-manual/group__avr__interrupts.html ISR(PCINT2_vect, ISR_NOBLOCK){
boolean odometryLeftState = digitalRead(pinOdometryLeft);
boolean odometryLeftState2 = digitalRead(pinOdometryLeft2);
boolean odometryRightState = digitalRead(pinOdometryRight);
boolean odometryRightState2 = digitalRead(pinOdometryRight2);
boolean motorMowRpmState = digitalRead(pinMotorMowRpm);
robot.setOdometryState(timeMicros, odometryLeftState, odometryRightState, odometryLeftState2, odometryRightState2);
robot.setMotorMowRPMState(motorMowRpmState);
// mower
//void rpm_interrupt(){
// WARNING: never use 'Serial' in the Ardumower code - use 'Console' instead
// (required so we can use
Arduino Due native port)
void Mower::setup(){
Wire.begin();
Console.begin(BAUDRATE);
//while (!Console) ; // required if using Due native port
Console.println("SETUP");
rc.initSerial(PFOD_BAUDRATE);
http://sobisource.com/arduino-mega-pwm-pin-and-frequency-timer-control/ //
http://www.atmel.com/images/doc2549.pdf #ifdef __AVR__
// NOTE: next line commented out so we can use default 450 Hz PWM freq (perimeter v2 otherwise uses the same freq band)
// TCCR3B = (TCCR3B & 0xF8) | 0x02; // set PWM frequency 3.9 Khz (pin2,3,5)
#endif
// i2c -- turn off internal pull-ups (and use external pull-ups)
//digitalWrite(SDA, 0);
//digitalWrite(SCL, 0);
// keep battery switched ON
pinMode(pinBatterySwitch, OUTPUT);
digitalWrite(pinBatterySwitch, HIGH);
// LED, buzzer, battery
pinMode(pinLED, OUTPUT);
pinMode(pinBuzzer, OUTPUT);
digitalWrite(pinBuzzer,0);
pinMode(pinBatteryVoltage, INPUT);
pinMode(pinChargeCurrent, INPUT);
pinMode(pinChargeVoltage, INPUT);
pinMode(pinChargeRelay, OUTPUT);
setActuator(ACT_CHGRELAY, 0);
// left wheel
motor
pinMode(pinMotorEnable, OUTPUT);
digitalWrite(pinMotorEnable, HIGH);
pinMode(pinMotorLeftPWM, OUTPUT);
pinMode(pinMotorLeftDir, OUTPUT);
pinMode(pinMotorLeftSense, INPUT);
pinMode(pinMotorLeftFault, INPUT);
// right wheel
motor
pinMode(pinMotorRightPWM, OUTPUT);
pinMode(pinMotorRightDir, OUTPUT);
pinMode(pinMotorRightSense, INPUT);
pinMode(pinMotorRightFault, INPUT);
// mower
motor
pinMode(pinMotorMowDir, OUTPUT);
pinMode(pinMotorMowPWM, OUTPUT);
pinMode(pinMotorMowSense, INPUT);
pinMode(pinMotorMowRpm, INPUT);
pinMode(pinMotorMowEnable, OUTPUT);
digitalWrite(pinMotorMowEnable, HIGH);
pinMode(pinMotorMowFault, INPUT);
brushless.attach(pinMotorMowPWM);
brushless.write(45);
// lawn sensor
pinMode(pinLawnBackRecv, INPUT);
pinMode(pinLawnBackSend, OUTPUT);
pinMode(pinLawnFrontRecv, INPUT);
pinMode(pinLawnFrontSend, OUTPUT);
// perimeter
pinMode(pinPerimeterRight, INPUT);
pinMode(pinPerimeterLeft, INPUT);
// button
pinMode(pinButton, INPUT);
pinMode(pinButton, INPUT_PULLUP);
// bumpers
pinMode(pinBumperLeft, INPUT);
pinMode(pinBumperLeft, INPUT_PULLUP);
pinMode(pinBumperRight, INPUT);
pinMode(pinBumperRight, INPUT_PULLUP);
// drops
pinMode(pinDropLeft, INPUT); // Dropsensor - Absturzsensor - Deklariert als Eingang
pinMode(pinDropLeft, INPUT_PULLUP); // Dropsensor - Absturzsensor - Intern Pullab Widerstand aktiviert (Auslösung erfolgt gegen GND)
pinMode(pinDropRight, INPUT); // Dropsensor - Absturzsensor - Deklariert als Eingang
pinMode(pinDropRight, INPUT_PULLUP); // Dropsensor - Absturzsensor - Intern Pullab Widerstand aktiviert (Auslösung erfolgt gegen GND)
// sonar
pinMode(pinSonarCenterTrigger, OUTPUT);
pinMode(pinSonarCenterEcho, INPUT);
pinMode(pinSonarLeftTrigger, OUTPUT);
pinMode(pinSonarLeftEcho, INPUT);
pinMode(pinSonarRightTrigger, OUTPUT);
pinMode(pinSonarRightEcho, INPUT);
// rain
pinMode(pinRain, INPUT);
// R/C
pinMode(pinRemoteMow, INPUT);
pinMode(pinRemoteSteer, INPUT);
pinMode(pinRemoteSpeed, INPUT);
pinMode(pinRemoteSwitch, INPUT);
// odometry
pinMode(pinOdometryLeft, INPUT_PULLUP);
pinMode(pinOdometryLeft2, INPUT_PULLUP);
pinMode(pinOdometryRight, INPUT_PULLUP);
pinMode(pinOdometryRight2, INPUT_PULLUP);
// user switches
pinMode(pinUserSwitch1, OUTPUT);
pinMode(pinUserSwitch2, OUTPUT);
pinMode(pinUserSwitch3, OUTPUT);
// other
pinMode(pinVoltageMeasurement, INPUT);
// enable interrupts
#ifdef __AVR__
// R/C
PCICR |= (1
