Thank you. Similar question about the White box plugs. I don't have enough to match the picture. But it does not say which ones I need to put in. Is there a way I should know what to do without asking here?
@W1976 Thank you for all your help. Can you show how the ESP32 is supposed to be mounted? I do not see a place in the board to put it. Should it just float around?I am at step 25 regrading the supposed installation of the ESP32. It says "Wiring to the circuit board 1.4 must also be created from there.". WTF? How are we supposed to mount this module? I assume the diagram on the page refers to the wifi module we did not install(those seven pins) but are we supposed to just grab some wire and start soldering it however we please? This whole section has me thoroughly confused. Any help would be appreciated. Thank you.
Thank you for your time and answers. What I have are three connections, and I am not sure which two to use. Is there a diagram somewhere? I have had trouble searching for an answer.3. On the Boardsides are large positive and negative prepared connector holes, take those, doesnt matter which ones.
Make sure your wires/screws cannot touch the aluminium profiles. Best would be to solder a connector or wire to them.
ThanksHappy Birthday
English or German?
What do you want to do? Charging? Can you make pictures of your progress, is everything finished?
The voltage in the App?
22:41:13.656 -> 0:0:38 ctlDur=0.02 op=0 freem=246959 sp=2000108C volt=0.00 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=268889000 lon=-137.41883885 lat=29.01550843 h=4999.0 n=0.00 e=0.00 d=0.00 sol=0 age=3.38
22:41:13.733 -> SWITCHING OFF (undervoltage)
[over and over]
Ok that is good. I did not know if I could choose either outside pin or if one specifically had to be used.What do you mean, 3 connections? On the Plug? Just measure conductivity. Inside pin is +, outside PINS is minus.
I have made an attempt at translating the available German document for the V1.4 mainboard into English. Considering I don't speak German, I had to rely heavily on Google translate and then correct any awkward language by hand afterward. Hopefully the result is useful for other English speakers. Now I can actually start assembling my board....
Hi shane smith, I did not understand you. You have bought a mainboard, but did not get any information from Marotronics?Can anyone get a reply from info@marotronics.de even after paying for main board no reply?
My mistake emails where going to spam
Ok, now all clear. I will write to the Ardumower Team by Skype, I hope you get very soon a answer. Can you tell me your purchase order number, please? I can speak with Markus from Marotronics, but I need the purchase order number.I got some emails to say that I have made the purchase. That has been a few days ago. Nothing to say it has been shipped or when I might receive it.
