Okay nach dem 28ten Versuch hat der HTTP Versuch der vollen Map jetzt funktioniert und Roboter ist unterwegs.
Ich vermute mal dass die ESP32 Version einfach Grütze ist die im aktuellen Sunray Release drin ist, muss ich nachher mal auf eine ältere wechseln.
I don't know what you mean, but in case of dock state cassandra shows up the reason for that (api, rain, schedule etc...)- Is it possible to add in mqtt the reason for the state: rain, low battery, ...?
Yes it is possible, just use LassoSelect or BoxSelect to selecting zone and confirm by clicking the confirm button under the map.- Is it possible in task planer to define zones to be cut instead of the whole map?
It is the prefered method for the route planner. This allows you to avoid the robot driving along the perimeter or you can connect two distant areas with a shorter route. It is also enables the robot to travel outside the perimeter if the wire is drawn outside.- What is the "search wire" for?
You will find a donation button at the end of readme file on github.PS: Where can I make a donation?
Yes that's it, is it possible to have this info in the MyCassandra mqtt?I don't know what you mean, but in case of dock state cassandra shows up the reason for that (api, rain, schedule etc...)
In Taskplanner, There's a button with only "Plan mow all", it doesn't take any selection into account.Yes it is possible, just use LassoSelect or BoxSelect to selecting zone and confirm by clicking the confirm button under the map.
Thanks !It is the prefered method for the route planner. This allows you to avoid the robot driving along the perimeter or you can connect two distant areas with a shorter route. It is also enables the robot to travel outside the perimeter if the wire is drawn outside.
Make your selection and click "confirm selection"In Taskplanner, There's a button with only "Plan mow all", it doesn't take any selection into account.
Do you mean API?Yes that's it, is it possible to have this info in the MyCassandra mqtt?
It's not working, now i have only "boot" statusOk
I add dock reason information to API.
Also I chaged button behavior on task page. It has the same behavior like on overview page. For path planning on whole map just click calc button, for path planning in the zone:
1. select the zone and
2. then click calc button. Also decribed in readme on github
Just the api or Cassandra itself?It's not working, now i have only "boot" status
Just the api, Cassandra works, but I did a roolback, I could try again probably friday afternoonJust the api or Cassandra itself?
Logfile might be helpful
Ist ab jetzt verfügbarFortschritt Prozentanzeige aus Cassandra (per MQTT) zugänglich machen?
Everything works !Est disponible maintenant
Super - Besten Dank!!!Ist ab jetzt verfügbar
