Rolf,hello anton, can you give us a source for the motor j57blrpg95? the manufacturer does not sell directly. on the website are also motors with brake. that would be something for the mower motor https://www.google.de/search?q=j57blrpg95&ie=UTF-8&oe=UTF-8&hl=de-de&client=safari best regards, rolf
I purchased the gear motors by:
86.21€ |100w 57mm bürstenloser Gleichstrom motor 24V mit Planeten getriebe verhältnis|DC-Motor| - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
For mowing I am using:
I have purchased a number of different motors to test with:
55.65€ |Gleichstrom motor mit Getriebe | 69W 42mm 24V Gleichstrom motor mit Planeten getriebe nema17 bürstenloser Motor-ali express
www.aliexpress.com
109.22€ |400W 60mm Bürstenlosen DC Motor 48V mit wurm getriebe Verhältnis 5:1/7.5:1/10:1/15:1/20:1/25:1/30:1/40:1/50:1/60:1/80:1/100:1 BLDC motor|DC-Motor| - AliExpress
www.aliexpress.com
I have also purchased this, but did not get it to work if I remember correctly:
28.59€ |Bürstenloser Gleichstrom motor 24V | 69W 3000 U/min 24V 0,22 N.m bürstenloser Gleichstrom motor Vierkant flansch 57mm Rund körper 3 Phasen
www.aliexpress.com
This is homepage of the producer:
The larger motors are reasonable quite, but the small makes a bit of noice in the gearbox. I used two small motors with the BLDC from marotronics last year until the drivers stopped working.
Anton
