Hi Stephan.
Hope Google translate correctly (my and your) post :lol: .
In fact i really don't understand why you wan't to put a Mega into the V1.3 board
The Mega work well with the 1.2 Board so for me if you buy a new PCB please change also the Mega by a Due.
I could be agree with you for the batery because there is a big difference between Li-Ion and Lead Acid or other type in charging and protecting method.
But for the Perimeter and Odo i am not agree and i don't understand your problem.
I use a Due on the V1.2 board and test ODO at very high speed without any problem 2880 ticks per rev at 25rpm .So if you do not want to run behind your lawnmower normaly no problem.
Not sure the 'ODOTAILER 4017 pcb' in V1.3 is mandatory ,but why not.
The perimeter and ADC work very well in background with the Alexander Sunray Class, i only have a little doubt for the
motor sense of MC33926 (not very stable but need to be confirm)
The one coil perimeter reading can be solve in 10ms so each 5 mm on a mower running at 0.4 Meter/Sec.
So for me all is OK With only one DUE board.
The only board i think it's good to connect to the
Arduino is a Raspberry PI for use it with Lidar,Camera,Screen,Computing Speed,Stockage etc....
Now for the V1.3 my little doubts are:
Complexity for Non-electronic person ??.
SMD Soldering and testing ??.
Price if SMD on board ??.
For the rest everything has been perfectly reflected, i thinks Uwez or all the people who worked on it did a tremendous and incredible job so again congratulation.
By a good week end.
Google try to translate.
Hallo Stephan.
Ich hoffe Google korrekt übersetzen (meine und Ihre) Post.
In der Tat ich wirklich nicht verstehen, warum Sie ein Mega in die V1.3-Platine setzen wollen.
Die Mega funktionieren gut mit dem 1.2 Board, also für mich wenn Sie eine neue Platine kaufen, ändern Sie bitte auch das Mega by a Due.
Ich könnte mit Ihnen für die Batterie zustimmen, weil es einen großen Unterschied zwischen Li-Ion und Blei-Säure oder andere Art bei der Aufladung und Schutzmethode.
Aber für den Perimeter und Odo bin ich nicht einverstanden und ich verstehe Ihr Problem nicht.
Ich benutze eine Fällig auf der V1.2-Platine und teste ODO bei sehr hoher Geschwindigkeit ohne jedes Problem 2880 Ticks pro Umdrehung bei 25 U / min. Also, wenn Sie nicht möchten, dass hinter Ihrem Rasenmäher normal kein Problem.
Ich bin nicht sicher, dass die 'ODOTAILER 4017 pcb' in V1.3 obligatorisch ist, aber warum nicht.
Die Perimeter und ADC arbeiten sehr gut im Hintergrund mit der Alexander Sunray Klasse, ich habe nur ein wenig Zweifel für den motorischen Sinn von MC33926 (nicht sehr stabil, aber muss bestätigt werden)
Die eine Spule Perimeter lesen kann in 10ms so alle 5 mm auf einem Mäher mit 0.4 Meter / Sekunde lösen gelöst werden.
Also für mich ist alles OK Mit nur einem DUE-Board.
Das einzige Brett, das ich denke, dass es gut ist, an das
Arduino anzuschließen, ist ein HimbeerePI für Gebrauch es mit Lidar, Kamera, Schirm, Rechengeschwindigkeit, Stockage usw. ....
Jetzt für die V1.3 meine kleinen Zweifel sind:
Komplexität für nicht-elektronische Person ??.
SMD Löten und Testen.
Preis wenn SMD an Bord ??.
Für den Rest war alles perfekt reflektiert, ich denke, Uwez oder alle Menschen, die daran gearbeitet hat eine enorme und unglaubliche Arbeit so wieder Glückwünsche.
Durch ein gutes Wochenende.
