if(str(message.topic)=="Mower/COMMAND/" or str(message.topic)=="Mower/COMMAND"):
if(str(responsetable[0]) == "RESTARTONLYPI"):
subprocess.Popen('/home/pi/Documents/PiArdumower/Restart.py')
if(str(responsetable[0]) == "HOME"):
button_home_click()
if(str(responsetable[0]) == "STOP"):
button_stop_all_click()
if(str(responsetable[0]) == "START"):
if(str(responsetable[0]) == "RESTARTALL"):
send_pfo_message('rx','1','2','3','4','5','6',)
button_home_click()
buttonStartMow_click()
else if (pfodCmd=="rx")
robot->autoReboot();
sendCommandMenu(true);
void Robot::rebootPi()
if (RaspberryPIUse)
Console.println(F("Send a command to Pi for reboot"));
MyRpi.sendCommandToPi("RestartPi");
What i see but not sureSometimes it lose wlan connection and need to reboot
payload: "STARTTIMER;{% if is_state('input_select.mower_timer1_mowpattern', 'Random') %}0{% elif is_state('input_select.mower_timer1_mowpattern', 'Lane') %}1{% elif is_state('input_select.mower_timer1_mowpattern', 'Perimeter') %}2{% else %}FAILED{% endif %};{{states('input_select.mower_timer1_lanenr')}};{% if is_state('input_select.mower_timer1_rolldir', 'Left') %}0{% elif is_state('input_select.mower_timer1_rolldir', 'Right') %}1{% else %}FAILED{% endif %};{{states('input_number.mower_timer1_start_distance')|round(0)}};{{states('input_select.mower_timer1_areatogo')}};{{states('input_number.mower_timer1_lane_lenght')|round(0)}}"
SUBSYSTEM=="tty", ATTRS{idVendor}=="2341", ATTRS{idProduct}=="003e", ATTRS{product}=="Arduino Due", SYMLINK+="ttyACM_DUE"
if DueConnectedOnPi:
try:
mymower.dueSerialReceived = Due_Serial.readline()
if str(mymower.dueSerialReceived) != "b''":
mymower.dueSerialReceived = str(mymower.dueSerialReceived, 'utf8')
if mymower.dueSerialReceived[:1] != '$': #it is console message because the first digit is not $
if (len(mymower.dueSerialReceived)) > 2:
consoleInsertText(mymower.dueSerialReceived)
else: # here a nmea message
# print(mymower.dueSerialReceived)
message = pynmea2.parse(mymower.dueSerialReceived)
decode_message(message)
# try:
# message = pynmea2.parse(mymower.dueSerialReceived)
# decode_message(message)
# except :
# # print('INCOMMING MESSAGE ERROR FROM DUE --> ' + str(mymower.dueSerialReceived))
# consoleInsertText('INCOMMING MESSAGE ERROR FROM DUE' + '\n')
# consoleInsertText(str(mymower.dueSerialReceived) + '\n')
except:
try:
print('Due serial connection fail, trying to reset')
Due_Serial.close()
time.sleep(5)
Due_Serial.open()
except:
print('Serial connection reset failed, shutdown 60s')
time.sleep(60)
fen1.destroy()
time.sleep(1)
print('Fen1 destroy')
time.sleep(1)
sys.exit('Impossible to continue')
19:51:19 Network check OK. Sending error email...
19:51:18 All Console file are saved
19:51:18 RTC data error!
19:51:18 DS1307 comm error
19:51:18 Watchdog triggered reboot done.
19:51:18 Watchdog is enabled and set to 5 seconds
19:51:18 off
19:51:18 v to change console output (sensor counters, values, perimeter etc.)
19:51:18 d for menu
19:51:18 press...
19:51:18 Config: ArduMower
19:51:18 Ardumower 1.2-Azurit-ber
19:51:18 START
19:51:18 capture size=192
19:51:18 subSample=4
19:51:18 matchSignal size=24
19:51:18 New sigcode in use : 1,1,-1,-1,1,-1,1,-1,-1,1,-1,1,1,-1,-1,1,-1,-1,1,-1,-1,1,1,-1,
19:51:18 Change to Area : 1
19:51:18 --------------------------------- IMU READY ------------------------------
19:51:18 AccelGyro Yaw: 0.00 Compass Yaw: 0.00 Diff between compass and accelGyro in Radian and Deg0.00 / 0.00
19:51:15 Wait 3 secondes to stabilize the Drift
19:51:15 DMP Initialization failed
19:51:12 Initializing DMP...
19:51:12 MPU6050 connection failed
19:51:10 .
19:51:10 comScale=2.00,2.00,2.00
19:51:10 COMPASS OFFSET X.Y.Z AND SCALE X.Y.Z --> comOfs=0.00,0.00,0.00
19:51:10 ACCEL GYRO MPU6050 OFFSET ax: 376 ay: -1768 az: 1512 gx: 91 gy: 12 gz: -2
19:51:10 -------- IMU CALIBRATION --------
19:51:09 IMU error: no calib data
19:51:08 COMPASS HMC5883L FAIL
19:51:08 COMPASS HMC5883L ID NEED TO BE 72 IF ALL IS OK ------> ID=0
19:51:08 --------------------------------- IMU INITIALISATION -------------------
19:51:08 Robot Stats address Stop = 826
19:51:08 Robot Stats address Start = 800
19:51:01 No rain in last 60 minutes
19:50:55 STATION / CHARG
19:50:55 STATION / STAT
19:50:55 Charge Voltage detected
19:50:54 BACKTOSTATION / STCHK
19:50:53 Detect a voltage on charging contact check if it's the station
19:50:48 Set New perimeter tracking speed 120
19:50:48 Change speed for 50 centimeters
19:50:48 RFID change tracking speed
19:50:48 RFID Tag find ToDO is: SPEED
19:50:48 Find a tag : 96D52480
I never see this message can you check it.No rain in last 60 minutes
In the past i use Piardy217 with it's own Access point and never freezeHello
In moment I am back to 217. Without Mqtt.
Can I use the new config with Mqtt settings? Or do I have to replace with old config?
I am asking because in moment I often have a freeze of Piardu. Only Piardu freeze. Not the Raspberry.
Thanks and best
Bjoern
if (Enable_DueWatchdog) {
Console.println ("Watchdog is enable and set to 2 secondes");
watchdogEnable(5000);// Watchdog trigger after 2 sec if not reseted.
02:09:48 Start to save all Console Data
02:09:48 PI Restart into 5 Seconds
02:09:48 MQTT Disconnected Code:0
02:09:47 Close Mqtt Connection
02:09:47 TIME TO RESTART
02:09:47 Due reset after 1 secondes, send a command to Pi for restart also
02:09:47 Time to Restart PI and Due
02:09:47 End of charging duration check the batfullCurrent to try to stop before
01:50:53 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 281
01:35:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 274
01:20:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 280
00:54:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 269
00:42:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 285
00:30:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 268
23:58:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 265
23:48:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 284
23:26:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 285
23:15:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 254
22:52:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 256
22:38:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 264
22:13:52 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 268
22:03:51 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 268
21:53:51 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 266
21:39:51 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 285
21:23:51 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 269
21:09:46 STATION / CHARG
21:09:46 ------ LOOP NOT OK DUE IS OVERLOAD -- Over 1 sec 528
21:09:46 STATION / STAT
21:09:46 Robot Stats address Stop = 826
YesCan I use the new config with Mqtt settings?
