// --- MC33926 motor driver ---
#define pinIN1 9 // M1_IN1 (if using old L298N driver, connect this pin to L298N-IN1)
#define pinIN2 8 // M1_IN2 (if using old L298N driver, leave open)
#define pinPWM 11 // M1_PWM / nD2 (if using old L298N driver, connect this pin to L298N-IN2)
#define pinEnable 3 // EN (connect to motor driver enable)
// motor driver fault pin
#define pinFault 12 // M1_nSF
#define USE_PERI_FAULT 0 // use pinFault for driver fault detection? (set to '0' if not connected!)
// motor driver feedback pin (=perimeter open/close detection, used for status LED)
#define USE_PERI_CURRENT 0 // use pinFeedback for perimeter current measurements? (set to '0' if not connected!)
#define pinFeedback A0 // M1_FB
#define PERI_CURRENT_MIN 0.1 // must be at least 100 mA for perimeter-is-closed detection
// ---- sender current control (via potentiometer) ----
// sender modulates signal (PWM), based on duty-cycle set via this potentiometer
#define USE_POT 1 // use potentiometer for current control? (set to '0' if not connected!)
#define pinPot A1 // 100k potentiometer (current control)
// ---- sender automatic standby (via current sensor for charger) ----
// sender detects robot via a charging current through the charging pins
#define USE_CHG_CURRENT 0 // use charging current sensor for robot detection? (set to '0' if not connected!)
#define pinChargeCurrent A2 // ACS712-05 current sensor OUT
#define CHG_CURRENT_MIN 0.050 // must be at least 50 mA for charging detection
// ---- sender status LED ----
#define pinLED 13 // ON: perimeter closed, OFF: perimeter open, BLINK: robot is charging
