11:40:54.241 -> Ardumower Sunray,1.0.230
11:40:54.241 -> compiled for:
Arduino Due
11:40:54.241 -> MOTOR_DRIVER_BRUSHLESS: yes
11:40:54.241 -> enableCharging 0
11:40:54.241 -> trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)9600...
11:40:54.721 -> BLE: AT
11:40:54.721 -> trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)115200...
11:40:55.421 -> BLE: AT
11:40:57.439 -> error: no BLE module found!
11:40:57.439 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
11:40:57.439 -> -----------------------------------------------------
11:40:57.439 -> UBLOX::begin serial
11:40:57.439 -> trying to connect to ublox f9p...
11:40:57.439 -> NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
11:40:57.439 -> trying baud 115200
11:41:00.734 -> ERROR: GPS receiver is not responding
11:41:00.734 -> trying baud 38400
11:41:01.004 -> GPS receiver found!
11:41:01.004 -> ublox f9p: sending GPS rover configuration...
11:41:01.004 -> idx=0...OK
11:41:01.004 -> idx=1...OK
11:41:01.038 -> idx=2...OK
11:41:01.038 -> config sent successfully
11:41:01.038 -> sizeof Point=4
11:41:01.038 -> map dump - mapCRC=0
11:41:01.038 -> points:
11:41:01.038 -> perimeter pts: 0
11:41:01.038 -> exclusion pts: 0
11:41:01.038 -> exclusions: 0
11:41:01.038 -> dock pts: 0
11:41:01.038 -> mow pts: 0
11:41:01.038 -> free pts: 0
11:41:01.038 -> mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3
11:41:01.526 -> WIFI (ESP8266) not found! If the problem persist, you may need to flash your ESP to firmware 2.2.1
11:41:01.526 -> MPU ID=0x0
11:41:01.526 -> MPU6050/9150/9250/9255 not found - Did you connect AD0 to 3.3v and choose it in config.h?
11:41:04.037 ->
11:41:04.037 -> 0:0:13 ctlDur=0.00 op=0 freem=81831 sp=2 volt=27.28 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.00 tow=466879000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=13.81
11:41:04.184 -> ublox chka error, msgclass=1, msgid=43, msglen=58: 0!=54
11:41:09.024 -> 0:0:18 ctlDur=0.02 op=0 freem=81831 sp=2 volt=27.30 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.00 tow=466887000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=18.81
11:41:14.048 -> 0:0:23 ctlDur=0.02 op=0 freem=81831 sp=2 volt=27.32 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.00 tow=466892000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=23.81
11:41:19.030 -> 0:0:28 ctlDur=0.02 op=0 freem=81831 sp=2 volt=27.33 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.00 tow=466897000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=28.81
11:41:24.033 -> 0:0:33 ctlDur=0.02 op=0 freem=81831 sp=2 volt=27.34 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.00 tow=466902000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=33.81
