//PID controller: track perimeter
void Robot::motorControlPerimeter() {
//3 states
//wire is lost
//On the wire staright line pid fast action
//Back slowly to the wire pid soft action
//Control the perimeter motor only each 30ms
if (millis() < nextTimeMotorPerimeterControl) return;
nextTimeMotorPerimeterControl = millis() + 30; //possible 15ms with the DUE
//tell to the pid where is the mower (Pid.x)
perimeterPID.x = 5 * (double(perimeterMag) / perimeterMagMaxValue);
//tell to the Pid where to go (Pid.w)
if (perimeterInside) {
perimeterPID.w = -0.5;
else {
perimeterPID.w = 0.5;
//parameter the PID
perimeterPID.y_min = -motorSpeedMaxPwm ;
perimeterPID.y_max = motorSpeedMaxPwm ;
perimeterPID.max_output = motorSpeedMaxPwm ;
//and compute
perimeterPID.compute();
//First state wire is lost
//important to understand TrackingPerimeterTransitionTimeOut It's if during this maximum duration the robot does not make a transition in and out then it is supposed to have lost the wire, the PID is stopped to go into blocking mode of one of the two wheels.
// If the trackingPerimeterTransitionTimeOut is too large the robot goes too far out of the wire and goes round in a circle outside the wire without finding it
// If the second condition is true the robot has lost the wire since more trackingPerimeterTransitionTimeOut (2500ms) for example it is then necessary to stop one of the 2 wheels to make a half turn and find again the wire
if ((millis() > stateStartTime + 10000) && (millis() > perimeterLastTransitionTime + trackingPerimeterTransitionTimeOut)) {
//If this condition is true one of the 2 wheels makes backward the other continues with the result of the PID (not advised)
if (trackingBlockInnerWheelWhilePerimeterStruggling == 0) { //
rightSpeedperi = max(-MaxSpeedperiPwm, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 + perimeterPID.y));
leftSpeedperi = -MaxSpeedperiPwm / 2;
else {
rightSpeedperi = -MaxSpeedperiPwm / 2;
leftSpeedperi = max(-MaxSpeedperiPwm, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 - perimeterPID.y));
//If this condition is true one of the 2 wheels stop rotate the other continues with the result of the PID (advised)
if (trackingBlockInnerWheelWhilePerimeterStruggling == 1) {
leftSpeedperi = 0;
else {
rightSpeedperi = 0;
//send to motor
setMotorPWM( leftSpeedperi, rightSpeedperi, false);
// we record The time at which the last wire loss occurred
lastTimeForgetWire = millis();
// if we have lost the wire from too long time (the robot is running in a circle outside the wire we stop everything)
if (millis() > perimeterLastTransitionTime + trackingErrorTimeOut) {
Console.println("Error: tracking error");
addErrorCounter(ERR_TRACKING);
//setNextState(STATE_ERROR,0);
setNextState(STATE_PERI_FIND, 0);
// out of the fonction until the next loop
return;
// here we have just found again the wire we need a slow return to let the pid temp react by decreasing its action (perimeterPID.y / 2)
if ((millis() - lastTimeForgetWire ) < trackingPerimeterTransitionTimeOut / 1.5 ) {
rightSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 + perimeterPID.y / 2));
leftSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 - perimeterPID.y / 2));
else
//we are in straight line the pid is total and not/2
rightSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm/1.5 + perimeterPID.y));
leftSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm/1.5 - perimeterPID.y));
//if the mower move in perfect straight line the transition between in and out is longuer so you need to reset the perimeterLastTransitionTime
if (abs(perimeterMag ) < perimeterMagMaxValue/4) {
perimeterLastTransitionTime = millis(); //initialise perimeterLastTransitionTime in perfect sthraith line
