Hello
Can Someone explain me, what I need to do, to get the ESP32 working? I don't understand what is meant by "sending a dummy message."
This is my log-File so far. Everything works fine, except the communication between the esp32 and the ardumower:
But sometime I get this message:
I thought about a cold solder joint or a defect ESP32. But I purchased a second ESP32 and can not find any cold solder joint.
RESET cause: power-on
Ardumower Sunray,1.0.187
compiled for: Adafruit Grand Central M4
MOTOR_DRIVER_BRUSHLESS: yes
enableCharging 0
trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)9600...
BLE: AT
trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)115200...
BLE: AT
error: no BLE module found!
SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
UBLOX::begin
trying to connect to ublox f9p...
NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
trying baud 115200
ERROR: GPS receiver is not responding
trying baud 38400
GPS receiver found!
ublox f9p: sending GPS rover configuration...
idx=0...OK
idx=1...OK
idx=2...OK
config sent successfully
sizeof Point=4
map load... no map file!
map dump - mapCRC=0
perimeter pts: 0
exclusion pts: 0
exclusions: 0
dock pts: 0
mow pts: 0
free pts: 0
WIFI (ESP8266) not found! If the problem persist, you may need to flash your ESP to firmware 2.2.1
MPU ID=0x68
MPU6050/9150 found
resuming is activated
state load... ok
dumpState: X=0.00 Y=0.00 delta=0.00 mapCRC=0 mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3 op=0 sensor=0 sonar.enabled=1 fixTimeout=0 absolutePosSource=0 lon=0.00 lat=0.00
temp=998.0 humidity=998 CPU: PTAT=838 CTAT=874 deg=35.69 voltages: I/O=3.34 Core=1.22 VBAT=1.66
0:0:12 ctlDur=0.00 op=0 freem=241291 sp=1 volt=23.19 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=331992000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=12.37
ublox chka error, msgclass=1, msgid=3C, msglen=40: 0!=B8
IMU gyro calibration (robot must be static)... 1
IMU gyro calibration (robot must be static)... 2
IMU gyro calibration (robot must be static)... 3
IMU gyro calibration (robot must be static)... 4
0:0:17 ctlDur=0.02 op=0 freem=241291 sp=1 volt=23.19 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=331997000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=0.13
IMU gyro calibration (robot must be static)... 5
IMU gyro calibration (robot must be static)... 6
IMU gyro calibration (robot must be static)... 7
IMU gyro calibration (robot must be static)... 8
IMU gyro calibration (robot must be static)... 9
0:0:22 ctlDur=0.02 op=0 freem=241291 sp=20001464 volt=23.20 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=0.76 tow=332002000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=5.14
0:0:27 ctlDur=0.02 op=0 freem=241291 sp=20001464 volt=23.20 chg=0.00 tg=0.00,0.00 x=0.00 y=0.00 delta=1.15 tow=332007000 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=10.14
enableCharging 0
BLE: AT
BLE: AT
OK
Bluetooth 4.0/BLE module found!
BLE: AT+VERSION
+VERSION=ESP32 firmware V0.2.4,Bluetooth V4.0 LE
BLE: AT+NAMEArdumower
+NAME=Ardumower
BLE: AT+RESET
+RESET
