Verdammt, ich verstehe nicht, warum die Konfiguration danach nicht funktioniert. Ich werde wieder einige Tests machen, aber ich kann nicht sehen, woher es kommt. Was sollten Logs @KadaverJoe sein?when trying to configure the rover ublox it refuses to use the configuration files from sunray, as the update is a 1.51 software version and the config files on sunray are for older software versions
I've already tried to downgrade it and it doesn't change anythingYou could also try to downgrade the ublox back to v1.32. With that one, it should safe work!
For 1.51 version You can try with the ardusimple config file (work for me) ,Maybe you lost the sat number in sunray app ,but fix is OK.I've already tried to downgrade it and it doesn't change anything
