Hi.
No like i tell you before the Timer and Plot Don't work actually on Randancer CCO.
The code into the Pi is not finish for that.
ALL IS MORE COMPLEX THAN THIS.
For me with the random mowing (NOT FOR BYLANE) mode there is no interest to start at a particular location on the wire except if you parcell your area with the wire because after 5 minutes the mower can be everywhere.
for example start at 5 ml after station and 10 minutes later the mower is at the opposite of the garden
When Start with timer,if you have a blocking station AND want to use the parcel area the mower need to first reverse and avoid the station reach the wire and track until find entry point or track CCW.
This Behaviour is not actually build in Raindancer.This work only for a not blocking station
But Roland have write the code so that the mower simply reverse ,rotate and start to mow and it's possible to start with Pi Timer if you finish to write the PI code parts.
Is it working well on the Pi Zero ??? you can see the video in 640*480 at 25fps using the WIFI .
What kind of Wifi sender or Box did you use ?
think that timer runs only in Pi
The Pi adjust is own time and date on startup if i remember it is read in data.py (all the starting $ data coming from due are decrypt here) and send to the Timerpage.py using OnReceiveSerialData.Where it gets time&date
