Problems Ardumower RTK/GPS KIT PCB 1.3 and DUE R3
In PCB 1 I was filled all solder up after it not work. So all solders look little big I think.
I was just melt little on this green stuff but I think they work as normal.
— New board PCB 1.3 Same issue with DUE R3 —
Using now completely new board and components and I have problem with this too. It is the Due R3 board that smelled after first connection. After this everything still seams to work Due Com Port but can not upload stuff.
Can it be Jumper JP13 that causing this when not connected with Maratonics DUE R3 board? Also can it be the Jumper JP8?? JP 8 is set on Dauer On to left. Correct??
Problem I got after first use:
set jumper JP13 on PCB back side for a Marotronics Arduino Due (i.e. Due clone) for automatic reset - Do NOT set this jumper for an original Arduino Due!
JP 8 it is only for shut down after 8 Min.
Your Soldering it is to hot,
German Falsch = Bad
German Falsch = Bad
I was fill up all soldering on card bacause of problem on PCB 1, that's why they look big and not good.
Here is images of PCB #2 and this works but the DUE R3 have problems its constant buzzer alarm and can not upload Fireware.
In Windows on programming port, I find it in Device manager but get error:
No device found on COM15
In Native USB port, I get: Unknown Device in Device manager
Did you install the motor drivers upside down?
This is how it should actually look. It looks like you have the wrong side of the driverboard.
Hi again,
I really think there is something wrong with the DUE R3 cards from https://www.marotronics.de/DUE-Entwicklungsboard-R3-32-Bit-ARM-Cortex-M3-Arduino-Kompatibel
Anyone tried and got Sunray to work with this card??
I connected the 2560 MEGA card to the new #2 PCB and this have Ardumower original and its no problem with this card.
What can be wrong?? Can I use MEGA 2560 instead of the DUE R3 and get Sunray to Work with BASE and ROVER GPS?
I just need to then upload Sunray to MEGA 2560. Any tips?
Thank you, It was this problem!!!
DUE R3 now works without *POFF* ;)
But think I may have a problem with motor driver:
Ardumower Sunray,1.0.72
enableCharging 0
trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)9600...
AT
trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)115200...
AT
00:29:28.949 -> SERIAL_BUFFER_SIZE=128 (increase if you experience GPS checksum errors)
00:29:28.949 -> -----------------------------------------------------
00:29:28.949 -> NOTE: if you experience GPS checksum errors, try to increase UART FIFO size:
00:29:28.949 -> 1. Arduino IDE->File->Preferences->Click on 'preferences.txt' at the bottom
00:29:28.949 -> 2. Locate file 'packages/arduino/hardware/sam/xxxxx/cores/arduino/RingBuffer.h
00:29:28.949 -> change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 1024
00:29:29.449 -> WIFI (ESP8266) not found!
00:29:29.449 -> MPU ID=0x0
00:29:29.449 -> MPU6050/9150/9250/9255 not found - Did you connect AD0 to 3.3v and choose it in config.h?
00:29:31.981 -> SWITCHING OFF (undervoltage)
00:29:32.159 -> temp=998.0 humidity=998
00:29:32.159 -> ctlDur=5.00 op=0 freem=44975 volt=4.12 chg=0.09 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=8.21
00:29:36.960 -> SWITCHING OFF (undervoltage)
00:29:37.178 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.52 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=13.21
00:29:41.974 -> SWITCHING OFF (undervoltage)
00:29:42.151 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.54 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=18.21
00:29:46.869 -> ERROR motor overload duration=20 current=0.00,0.00,2.00
00:29:46.903 -> ERROR motor overload duration=40 current=0.00,0.00,2.00
00:29:46.972 -> SWITCHING OFF (undervoltage)
00:29:46.972 -> ERROR motor overload duration=60 current=0.00,0.00,2.01
00:29:47.010 -> ERROR motor overload duration=80 current=0.00,0.00,2.01
00:29:47.081 -> ERROR motor overload duration=100 current=0.00,0.00,2.01
00:29:47.118 -> ERROR motor overload duration=120 current=0.00,0.00,2.02
00:29:47.151 -> ERROR motor overload duration=140 current=0.00,0.00,2.02
00:29:47.151 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.54 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=23.21
00:29:47.221 -> ERROR motor overload duration=160 current=0.00,0.00,2.02
2 try
01:39:56.563 -> [WiFiEsp] Initilization successful - 1.5.4
01:39:56.563 -> [WiFiEsp] >>> TIMEOUT >>>
01:39:56.563 -> [WiFiEsp] No tag found
01:39:56.563 -> ERROR: WiFi not present
01:39:56.563 -> MPU ID=0x0
01:39:56.563 -> MPU6050/9150/9250/9255 not found - Did you connect AD0 to 3.3v and choose it in config.h?
01:39:58.841 -> SWITCHING OFF (undervoltage)
01:39:58.841 -> Error: motor right fault
01:39:58.841 -> Error: motor mow fault
01:39:59.021 -> temp=998.0 humidity=998
01:39:59.021 -> ⸮UjP⸮TJH⸮AT+CIPSTATUS
01:39:59.021 -> CRC ERROR
01:39:59.021 ->
01:39:59.021 -> ctlDur=5.00 op=0 freem=44975 volt=4.47 chg=0.09 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=4200 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=10.14
01:39:59.831 -> Reset motor right fault
01:39:59.831 -> Reset motor mow fault
01:39:59.864 -> Error: motor right fault
01:39:59.864 -> Error: motor mow fault
01:40:00.931 -> Reset motor right fault
01:40:00.931 -> Reset motor mow fault
01:40:00.965 -> Error: motor right fault
01:40:00.965 -> Error: motor mow fault
01:40:02.042 -> Reset motor right fault
01:40:02.042 -> Reset motor mow fault
01:40:02.079 -> Error: motor right fault
01:40:02.079 -> Error: motor mow fault
01:40:26.114 -> Ardumower Sunray,1.0.72
01:40:26.114 -> enableCharging 0
01:40:26.114 -> trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)9600...
01:40:26.114 -> AT
01:40:26.628 -> trying to detect Bluetooth 4.0/BLE module (make sure your phone is NOT connected)115200...
01:40:26.628 -> AT
01:40:27.133 -> SERIAL_BUFFER_SIZE=128 (increase if you experience GPS checksum errors)
01:40:27.133 -> -----------------------------------------------------
01:40:27.133 -> NOTE: if you experience GPS checksum errors, try to increase UART FIFO size:
01:40:27.133 -> 1. Arduino IDE->File->Preferences->Click on 'preferences.txt' at the bottom
01:40:27.133 -> 2. Locate file 'packages/arduino/hardware/sam/xxxxx/cores/arduino/RingBuffer.h
01:40:27.133 -> change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 1024
01:40:27.602 -> WIFI (ESP8266) not found!
01:40:27.602 -> MPU ID=0x0
01:40:27.602 -> MPU6050/9150/9250/9255 not found - Did you connect AD0 to 3.3v and choose it in config.h?
01:40:30.135 -> SWITCHING OFF (undervoltage)
01:40:30.308 -> temp=998.0 humidity=998
01:40:30.308 -> ctlDur=5.00 op=0 freem=44975 volt=4.19 chg=0.09 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=8.21
01:40:35.104 -> SWITCHING OFF (undervoltage)
01:40:35.318 -> ctlDur=0.02 op=0 freem=44975 volt=4.19 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=13.21
01:40:40.118 -> SWITCHING OFF (undervoltage)
01:40:40.339 -> ctlDur=0.02 op=0 freem=44975 volt=4.15 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=18.21
01:40:45.130 -> SWITCHING OFF (undervoltage)
01:40:45.311 -> ctlDur=0.02 op=0 freem=44975 volt=4.15 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=23.21
01:40:50.112 -> SWITCHING OFF (undervoltage)
01:40:50.320 -> ctlDur=0.02 op=0 freem=44975 volt=4.15 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=28.21
01:40:55.123 -> SWITCHING OFF (undervoltage)
01:40:55.338 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=33.21
01:41:00.124 -> SWITCHING OFF (undervoltage)
01:41:00.340 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.50 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=38.21
01:41:05.137 -> SWITCHING OFF (undervoltage)
01:41:05.320 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.50 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=43.21
01:41:10.136 -> SWITCHING OFF (undervoltage)
01:41:10.318 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=48.21
01:41:15.105 -> SWITCHING OFF (undervoltage)
01:41:15.320 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=53.22
01:41:20.120 -> SWITCHING OFF (undervoltage)
01:41:20.335 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=58.22
01:41:25.126 -> SWITCHING OFF (undervoltage)
01:41:25.332 -> ctlDur=0.02 op=0 freem=44975 volt=4.12 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=63.22
01:41:30.128 -> SWITCHING OFF (undervoltage)
01:41:30.306 -> temp=998.0 humidity=998
01:41:30.343 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=68.22
01:41:35.110 -> SWITCHING OFF (undervoltage)
01:41:35.317 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=73.22
01:41:40.120 -> SWITCHING OFF (undervoltage)
01:41:40.328 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=78.22
01:41:45.116 -> SWITCHING OFF (undervoltage)
01:41:45.327 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=83.22
01:41:50.115 -> SWITCHING OFF (undervoltage)
01:41:50.324 -> ctlDur=0.02 op=0 freem=44975 volt=4.05 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=88.22
01:41:55.128 -> SWITCHING OFF (undervoltage)
01:41:55.333 -> ctlDur=0.02 op=0 freem=44975 volt=4.05 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=93.22
01:42:00.119 -> SWITCHING OFF (undervoltage)
01:42:00.329 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=98.22
01:42:05.125 -> SWITCHING OFF (undervoltage)
01:42:05.331 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=103.22
01:42:10.130 -> SWITCHING OFF (undervoltage)
01:42:10.341 -> ctlDur=0.02 op=0 freem=44975 volt=4.08 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=108.23
01:42:15.116 -> SWITCHING OFF (undervoltage)
01:42:15.330 -> ctlDur=0.02 op=0 freem=44975 volt=4.05 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=113.23
01:42:20.111 -> SWITCHING OFF (undervoltage)
01:42:20.333 -> ctlDur=0.02 op=0 freem=44975 volt=4.05 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=118.23
01:42:25.137 -> SWITCHING OFF (undervoltage)
01:42:25.342 -> ctlDur=0.02 op=0 freem=44975 volt=4.05 chg=0.49 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 n=0.00 e=0.00 d=0.00 sol=0 age=123.23
01:42:30.127 -> SWITCHING OFF (undervoltage)
01:42:30.339 -> temp=998.0 humidity=998
I would test another motor driver, I suspect that you destroyed yours with the faulty connection.
Is your battery empty or how do you supply the PCB? If your battery is full, it may be that your INA is also damaged.
Ok thank you! I try change to new motor drivers and the battery was pretty empty so I going to charge this.
Reporting later. Thx again!! 🙏🙏🙏
if you discharge the battery pack down to 4V, the LiPo cells can be damaged. A deep discharge leads to the destruction of the cells ...
Or is the display incorrect?
Yeees it was at 6 V so hopefully battery is good. Now I changed to new Motordrivers and everything seams to wooork Jiipii! Thank you holunder!!!!
I never figure out that I was installed motordriver wrong way, I dont know how I did this. Maby tired when doing, and on 2 PCB lol!!
Thx again. I send videos when im operating soon. I going to add more sensors and stuff but now first I need to test GPS etc.
I was load battery but it drains out really fast. I trying to charge now again and we see. :)
6V with a LiPo 7S2P is a deep discharge.
Be careful with the cells that they don´t explode.
Charge the LiPo cells only in a fire-proof container, as charging current take 50mAh to 100mAh, no more. If you're lucky, your cells will have survived, at least some of them. Better use a BMS with balancer for the future, this saves your battery and costs ~ 15 €.
The batteries must not become hot when charging and discharging. When the battery gets hot, put it outside in the fire-proof container.
Ok, thx for this info! It's important and good to write about this in the WIKI that BMS is "needed". Maby sell BMS in the Ardumower KIT or in the battery company website https://www.asn-shop.de/. Where can I buy the BMS?
when I connect to charging now it takes really long time to charge. I was charge for 3h and battery Volt is 13,74. I dont know of its really charging? I send photos on my setup.
i have not installed the emegancy switch. I have just a metall thing in P49
a BMS is not necessary, just better. In normal operation, the battery does not discharge to the extent that it is previously switched off by the software.
A hint in the wiki would certainly make sense.
The emergency switch is not connected to P49, so your jumper is just right. The switch is connected in the supply line from the battery to the PCB. This is the only way to really disconnect the ardumower in an emergency.
Ok I have now a BMS. How do I connect this correct?
I have 7 cables on bms. + 1 2 3 4 5 6 and then I can solder on the card for BAT - and P -
The cable from Ardumower Battery have 8 small cables. And + and -
Without opening the battery, I would say that the 6 white cables are 1 to 6 on the BMS. It is allways one cable between 2 cells (or cell blocks). A 7S battery has 6 cables for the balancer (always one cable less than the number in front of the S). The red and black cables in the connector are the charging cables, which are connected to a BMS with separate charging and discharging inputs.
Can you post the data sheet from the BMS?
Try the following. Only connect the cables from the plug as follows, but do not plug them into the BMS !:
+ -> connect the red thin cable to + and the red thick cable
BAT-> black cable
now you have to measure with the multimeter. the white cables are increasing in voltage and must be connected in the correct order. Therefore, b1 ~ 4V, b2 ~ 8V, etc.
Plug the multimeter into the thin black cable and search for the white cable with 4V. This is then connected to 1. Then you look for the second cable with 8V and connect it to 2. You do this with all white cables.
If everything is connected correctly, insert the plug into the BMS and then you should have your battery voltage between the red thick cable and "Pack-".
The red thick cable goes into the emergencyswitch and from there to "P43 +" on the PCB. "PACK-" is connected directly to "P43-" on the PCB.
This is how it should work, but from a distance without having to do it in hand no guarantee.
