SefanH
In der Console scheint alles zu laufen.
Der Upload scheint auch fehlerfrei zu sein.
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13516
load:0x40080400,len:3604
entry 0x400805f0
[WSB] ESP32 Serial WIFI Bridge with Webinterface vom 22.04.2021
[WSB] Connecting with programmed settings
[WSB] Connecting ...0
[WSB] Connecting ...1
[WSB] Connecting ...2
[WSB] Connecting ...3
[WSB] Connecting ...4
[WSB] Connecting ...5
[WSB] Connecting ...6
[WSB] Connecting ...7
[WSB] CONNECTED! IP address: 192.168.178.123
[SPIFFS] data : C:\Users\sefan\Documents\Arduino\MowerWebControl_ESP32_22042021\data
[SPIFFS] start : 2686976
[SPIFFS] size : 1472
[SPIFFS] page : 256
[SPIFFS] block : 4096
/ADCcalib.html
/commands.html
/design.css
/error.html
/functions.js
/index.html
/info.html
/logo.png
/logo_small.png
/manual.html
/settings/batt.html
/settings/bumperduino.html
/settings/datetime.html
/settings/drop.html
/settings/gps.html
/settings/imu.html
/settings/index.html
/settings/lawn.html
/settings/motor.html
/settings/mow.html
/settings/odo.html
/settings/perimeter.html
/settings/rain.html
/settings/rc.html
/settings/sonar.html
/settings/station.html
/settings/vorlage.html
/virtualjoystick.js.html
[SPIFFS] upload : C:\Users\sefan\AppData\Local\Temp\arduino_build_709000/MowerWebControl_ESP32_22042021.spiffs.bin
[SPIFFS] address: 2686976
[SPIFFS] port : COM6
[SPIFFS] speed : 921600
[SPIFFS] mode : dio
[SPIFFS] freq : 80m
esptool.py v3.3
Serial port COM6
Connecting....
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:c6:f7:2f:7d:3c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00290000 to 0x003fffff...
Compressed 1507328 bytes to 116677...
Writing at 0x00290000... (12 %)
Writing at 0x002a1959... (25 %)
Writing at 0x002a9a5a... (37 %)
Writing at 0x002b1cf3... (50 %)
Writing at 0x002ba262... (62 %)
Writing at 0x002dd399... (75 %)
Writing at 0x00303fde... (87 %)
Writing at 0x0033c0fe... (100 %)
Wrote 1507328 bytes (116677 compressed) at 0x00290000 in 8.6 seconds (effective 1396.3 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
