Parts list and information about the print files
markus
Administrator
Teammitglied
Everything you need for the 3D Ardumower.
This list is still incomplete and will be completed.
Electronics set for the 3D Ardumower. Version 2.00 in the Marotronics Shop
Aluminum profiles and screws:
3D printer files : Thingiverse
Are there drawings available from the new mower.
Mainly from the inside with the metal construnction?
Thanks for help.
I'm also bit confused about Alu profiles for the mower.
In Fusion, some profiles are wrong but It seems to me that we need
- 1x 30mm for the back side of motor boxes
- 2x 300 soming from motor boxes to front wheel as main structure
- 4x 98mm to support mow motors
In Fusion, there is a small profile of 96mm on the front of traction motor box, but this can't be mounted here.
Anyone out there who can confirm?
Not sure what you mean by 30mm for the back side of motor boxes.
I've ended up using:
- 4x98mm (doesn't have to be precise) for mow motors
- 2x300mm+ (not precise) for main structure (without going inside motor boxes themselves as is shown in fusion file)
- 365mm on the back side of the motor box going from one end to another on the back side (more precisely that would be ~370mm, but didnt' wanted it touching the side walls)
I'll add pics to my experience threads
Hello,
thanks for confirmation. 1x30 was a typo, It should be 1x360mm and is what you measured as 365mm.
