DEBUG Backend: Calc data from state data frame
2023-07-03 12:56:33 INFO Backend: Planning route:
2023-07-03 12:56:33 INFO PathPlannerCfg(pattern='lines', width=0.18, angle=0, distancetoborder=2, mowarea='yes', mowborder='yes', mowexclusion='yes', mowborderccw='yes')
2023-07-03 12:56:33 INFO Rover start position: [-3.3, -2.5]
2023-07-03 12:56:33 INFO Backend: Turning shapely figure: Point Angle: 0
2023-07-03 12:56:33 DEBUG POINT (-3.3 -2.5)
2023-07-03 12:56:33 INFO Backend: Turning shapely figure: Polygon Angle: 0
2023-07-03 12:56:33 DEBUG POLYGON ((15.0007553298 -1.3057197624999999, 13.85 -1, 12.62 -0.99, 10.4 -3.27, 10.12 -3.38, 9.6042603392 -3.0141307447, 9.47 -2.92, 9.15 -3.08, 7.3533463871 -5.133861224, 4.5816023941 -3.1872315025, 3.2152812471 -2.1384963657, 2.9 -2.5700000000000003, 2.6929709276000002 -3.3619531786, 0.48 -6.36, 0.14 -6.35, 0.166514459 -5.7240491746, -0.0949650808 -5.4596117983, -0.3193228897 -5.1458343018, -0.6578034237 -4.8481431357, -2.0976490456 -3.7974893477, -2.4124308033 -3.5472782069, -2.6752167469 -3.3571490013, -2.84 -3.24, -2.55 -2.94, -2.1122960911 -2.9156222427, -1.7393403098 -2.4669098184, -1.8539131573 -2.0958574687000002, -1.5322415862 -1.7290417971, -1.3140937016 -1.6392161975000001, -0.8891733092 -1.0888619290000001, -0.92 -0.73, 0.2649397385 0.3007515673, 0.8151943529 -0.1278448501, 1.5967145497000002 -0.5137859410000001, 2.0749754593 -0.5768533137, 2.6898823431 -0.6136426145, 3.36 -0.6900000000000001, 3.5640589140000003 -0.7821047824, 3.3283214103 -1.7799637766, 4.6047118813 -2.6734550993, 5.01 -0.09, 5.39 1.5899999999999999, 5.62 1.83, 6.01 2.08, 6.27 1.79, 5.65 0.88, 5.8535069382 0.7413855669, 7.2619968762 -0.2297344176, 8.6741116572 1.4665795646, 7.2264719761 2.7277135199, 8.58 3.7, 11.7380836188 1.2415696411, 12.940047269 0.3117487042, 13.3 0.12, 13.77 0.08, 14.25 0.35, 16.6371328073 3.1833371654000002, 18 1.97, 15.2509934903 -1.2554747636, 15.8885166071 -1.50894781, 17.4083734456 -1.9576286937, 18.09 -1.08, 21.06 2.75, 21.23 3.19, 21.2456078793 3.6442556684, 21.2 3.93, 21.0708176875 4.2162962963, 20.89 4.4, 20.6497322253 4.5023166102, 20.36 4.54, 20.06180158 4.5261516364, 19.7093197954 4.3111501557, 18.6178258367 5.1601557654, 18.4420129271 5.3176731302, 18.4241366574 5.5858171745, 21.6177965502 9.803133889, 21.83 9.75, 23.2 8.28, 23.3 7.86, 25.0879151126 6.5880188699, 25.5 6.6, 25.93 6.17, 26.03 5.71, 22.608141463 1.5453093715000001, 19.2830748859 -2.7450991151, 18.7112273973 -3.2799488914, 18.582386038 -3.2245998091, 18.4 -3.14, 17.62 -2.51, 17.0916024292 -2.0999174979, 16.6215670347 -1.9054200933, 15.0007553298 -1.3057197624999999), (5.3589967448 -0.4850987407, 4.9010198038 -1.3256211266, 5.8654653619 -1.9560129159000001, 6.3557700869 -1.1047146021, 5.3589967448 -0.4850987407), (9.7060692249 -0.8697987312000001, 9.1068675862 -1.5519667506000001, 10.1814089235 -2.3183052743, 10.745366327 -1.5663620695, 9.7060692249 -0.8697987312000001), (11.8515471861 -0.0970835922, 10.8399430949 0.6696885557000001, 10.2223044828 -0.1507567649, 11.2308978123 -0.8681934202, 11.8515471861 -0.0970835922), (22.7719899676 5.3089227951, 22.9333313964 5.1475813664, 23.2099167027 5.0400204139, 23.455770308399998 5.1475813664, 23.6171117371 5.4011178972, 23.5556483357 5.6700202784, 23.3635752063 5.8467275575, 23.0946728251 5.8851421833, 22.8334533691 5.8083129316, 22.7105265662 5.5240447, 22.7719899676 5.3089227951))
2023-07-03 12:56:33 INFO Backend: Create map borders and area to mow
2023-07-03 12:56:33 INFO Backend: Calc route for cutedge
2023-07-03 12:56:33 ERROR Exception on /_dash-update-component [POST]
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 2190, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1486, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1484, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1469, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/usr/local/lib/python3.10/site-packages/dash/dash.py", line 1283, in dispatch
ctx.run(
File "/usr/local/lib/python3.10/site-packages/dash/_callback.py", line 450, in add_context
output_value = func(*func_args, **func_kwargs) # %% callback invoked %%
File "/usr/src/cassandra/src/components/state/map.py", line 54, in update
path.calc(pathplannercfgstate, rover_position)
File "/usr/src/cassandra/src/backend/map/path.py", line 20, in calc
route, edge_polygons = cutedge.calcroute(border, parameters, list(start_pos.coords))
File "/usr/src/cassandra/src/backend/map/cutedge.py", line 58, in calcroute
for i in range(rounds):
TypeError: 'str' object cannot be interpreted as an integer
