2023-05-24 06:18:38 INFO Dash is running on
http://0.0.0.0:8050/
* Serving Flask app 'app'
* Debug mode: off
2023-05-24 06:18:39 ERROR Exception on /_dash-update-component [POST]
File "/usr/local/lib/python3.10/site-packages/dash/dash.py", line 1230, in dispatch
cb = self.callback_map[output]
KeyError: 'modal-info-body.children'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 2190, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1486, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1484, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.10/site-packages/flask/app.py", line 1469, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/usr/local/lib/python3.10/site-packages/dash/dash.py", line 1279, in dispatch
raise KeyError(msg) from missing_callback_function
KeyError: "Callback function not found for output 'modal-info-body.children', perhaps you forgot to prepend the '@'?"
KeyError: '..button-home.disabled...button-mow-all.disabled...button-zone-select.disabled...button-goto.disabled...button-cancel.disabled..'
KeyError: "Callback function not found for output '..button-home.disabled...button-mow-all.disabled...button-zone-select.disabled...button-goto.disabled...button-cancel.disabled..', perhaps you forgot to prepend the '@'?"
KeyError: '..button-go.active...button-stop.active..'
KeyError: "Callback function not found for output '..button-go.active...button-stop.active..', perhaps you forgot to prepend the '@'?"
KeyError: 'state-map.figure'
KeyError: "Callback function not found for output 'state-map.figure', perhaps you forgot to prepend the '@'?"
2023-05-24 06:18:40 WARNING Backend: HTTP-Connection to the rover lost or not possible. Trying to reconnect
2023-05-24 06:18:40 INFO Backend: Try initial HTTP request
