Die Service-Datei beantwortet diese Fragen denke ich:
[Unit]
Description=CaSSAndRA
After=multi-user.target
[Service]
#Euer Benutzername
User=oliver
Type=simple
Restart=always
#ExecStart: ggf. Pfad zu eurer app.py anpassen
ExecStart=python3 /home/oliver/CaSSAndRA/CaSSAndRA/app.py
[Install]
WantedBy=multi-user.target
Ich stolpere so voran. Ich habe den Dienst nochmal gestoppt und die App noch einmal direkt gestartet. Hier sind Fehler deutlich sichtbar:
oliver@raspberrypi:~/CaSSAndRA/CaSSAndRA $ python3 app.py
2023-05-12 09:19:58 INFO Backend: Starting backend server
2023-05-12 09:19:58 INFO Backend: Read communication config file
2023-05-12 09:19:58 INFO Backend: Used connection: MQTT
2023-05-12 09:19:58 INFO Backend: Read map config file
2023-05-12 09:19:58 INFO Backend: Read app config file
2023-05-12 09:19:58 INFO Backend: Read saved data
2023-05-12 09:19:58 INFO Backend: State data are loaded successfully
2023-05-12 09:19:58 INFO Backend: Statistics data are loaded successfully
2023-05-12 09:19:58 INFO Backend: Calced data from state are loaded successfully
2023-05-12 09:19:58 INFO Backend: Calced data from stats are loaded successfully
2023-05-12 09:19:58 INFO Backend: Read map data file
2023-05-12 09:19:58 WARNING Backend: Selected perimeter name is an empty string. Please upload or create a new perimeter
2023-05-12 09:19:58 INFO Backend: Establishing MQTT connection to the MQTT-Server
2023-05-12 09:19:58 INFO Backend: Connection to the MQTT-Server succsessfull
2023-05-12 09:19:58 INFO Backend: Starting server thread
2023-05-12 09:19:58 INFO Backend: Backend is successfully started
2023-05-12 09:19:58 INFO Backend: Subscriptions to the rover MQTT topics succsessfull
2023-05-12 09:19:58 WARNING Backend: Could not connect to the rover. State set to offline
Dash is running on http://0.0.0.0:8050/
2023-05-12 09:20:00 INFO Dash is running on http://0.0.0.0:8050/
* Serving Flask app 'app'
* Debug mode: off
2023-05-12 09:20:19 ERROR Exception on /_dash-update-component [POST]
  File "/home/oliver/.local/lib/python3.9/site-packages/dash/dash.py", line 1230, in dispatch
    cb = self.callback_map[output]
KeyError: 'modal-info-body.children'
The above exception was the direct cause of the following exception:
  File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 2190, in wsgi_app
    response = self.full_dispatch_request()
  File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1486, in full_dispatch_request
    rv = self.handle_user_exception(e)
  File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1484, in full_dispatch_request
    rv = self.dispatch_request()
  File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1469, in dispatch_request
    return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
  File "/home/oliver/.local/lib/python3.9/site-packages/dash/dash.py", line 1279, in dispatch
    raise KeyError(msg) from missing_callback_function
KeyError: "Callback function not found for output 'modal-info-body.children', perhaps you forgot to prepend the '@'?"
2023-05-12 09:21:14 ERROR Backend: Failed to write state data to data frame
cp /home/oliver/CaSSAndRA/bugfix_dash_daq_min/dash_daq.min.js dash_daq.min.js habe ich ausgeführt.
2023-05-12 09:20:19 ERROR Exception on /_dash-update-component [POST] Traceback (most recent call last): File "/home/oliver/.local/lib/python3.9/site-packages/dash/dash.py", line 1230, in dispatch cb = self.callback_map[output] KeyError: 'modal-info-body.children' The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 2190, in wsgi_app response = self.full_dispatch_request() File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1486, in full_dispatch_request rv = self.handle_user_exception(e) File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1484, in full_dispatch_request rv = self.dispatch_request() File "/home/oliver/.local/lib/python3.9/site-packages/flask/app.py", line 1469, in dispatch_request return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args) File "/home/oliver/.local/lib/python3.9/site-packages/dash/dash.py", line 1279, in dispatch raise KeyError(msg) from missing_callback_function KeyError: "Callback function not found for output 'modal-info-body.children', perhaps you forgot to prepend the '@'?"
Der Fehler kommt fast immer nach dem Neustart, da habe ich noch keine Lösung für, der beinflusst aber nicht die Funktion der App.
Hier kam was unplausibles über MQTT, solange es nicht dauernd kommt ist alles in Ordnung. Ich ändere mal die Meldung auf Warning.
Die App sollte ohne Probleme laufen
Bei mir gehen die Mähbahnen seit gestern durch eine Exclusion durch. Was kann da die Ursache sein?
Da stimmt auch was mit dem Dockingpfad nicht.
Wieviele Karten sind geladen? Evtl gleichen Namen für die Karte vergeben (das wird leider noch nicht abgefangen)
- perimeter.json löschen und Karten neue importieren
- evtl auf die neuste Version aus GitHub wechseln
Danke, ich hatte die Karte 2x mit gleichem Namen. Die neueste Version aus GitHub von heute 11:44 Uhr habe ich schon.
Ist der Button Wolke mit Minus aktiv, um eine Karte zu löschen? Das hatte ich nämlich probiert, aber die Karte blieb da.
@Weitenbummler
Falls Du noch immer Probleme mit speichern von Daten hast, gehe mal in den Ordner
cd /home/oliver/CaSSAndRA/CaSSAndRA/src
Und vergib mal die Rechte für Deinen User, den Du für den Service nutzt:
chown -R oliver data/
chmod -R 777 data/
Es schadet aber auch nichts, wenn Du das gleich auf den ganzen CaSSAndRA-Odner im /home/oliver machst.
Idealerweise startest Du dann die App auch nur noch unter diesem User, also auch ohne sudo. Nicht dass die Rechte hinterher noch einmal verrutschen weil noch eine neue Datei als root angelegt wird.
habe es heute dank euch geschafft CaSSAndRA auf einem Raspberry Pi 400 ans laufen zu bekommen, danke.
Allerdings habe ich unter Mappings 2 mal die selbe Karte drin und bekomme diese nicht gelöscht, die Perimeter.json habe ich schon gelöscht.
Wie kann ich alles überschreiben ?
@EinEinach saubere Arbeit, meinen Respekt hast du (y)
Nach einem Neustart war die Karte weg, aber ich schaffe es nicht Mähbahnen zu erstellen.
Wenn ich okay drücke passiert nix, nur einmal ganz am Anfang hat er was erstellt.
Was mache ich falsch ?
Den Löschbutton mache ich demnächst funktional, sorry hätte ich vllt mit dem Update warten sollen.
Bitte gebt euren Karten eineindeutigen Namen
Drücke mal auf die Karte neben dem Häuschen und warte einbisschen, der raspberry braucht ein wenig Zeit zum berechnen. Bzw. deine Karte sieht recht interessant aus, sind es zwei Zonen? Ist da keine Durchfahrt zwischen?
Oder klicke auf die Karte mit der Pinnadel und wähle oben den Lasso Werkzeug oder Box selection, danach gewünschte Stelle, die gemäht werden soll, auf der Karte markieren. Sollte Cassandra keine Mähwege berechnen, dann brauche ich Log Auszug.
jetzt geht es , hatte immer nur eingestellt was er berrechnen soll ohne auf die Karte zu klicken.
Die Map sind 2 Rasenflächen die durch einen Weg getrennt sind, habe die Überfahrt einfach als schmalen Perimeter gemacht.
Mal sehen was er da macht bei deiner Berechnung.
Aufpassen, da bügelt er teilweise durch die exclusions bei dir durch, hoffentlich keine Teichs, das ist ein Fehler in der Berechnung bei mir, denn ich demnächst angehen werde.
Damit das nicht passiert sollte die Exclusion mit etwas mehr Punkten angelegt werden (8-10 Punkte pro Exclusion) Möglichst nah bei einander
