holunder
The Welder spot is more a hobby than controlled work ...
take one of your cells and measure how much capacity they actually have.
Why don't you use 21700 (LG Chem INR21700-M50T - 5000mAh) cells if you build the battery yourself anyway?
The cells are also a little less sensitive and would work with your BMS.
Unfortunately I don't have any BMS sources for end customers.
Before you build your next battery, fully charge all cells, measure, wait 24 hours, measure again and only use cells where the voltage has not changed.
