Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Hello. Sunray firmware does not support automatic charge-and-resuming operation yet. I'm working on trying out RTK-based docking but it's complicated ... docking with float-only solution may work, but undocking with float-only solution can be tricky (if it should work cm-precise). But first experiments show it could work using odometry and IMU only. Currently, I'm using two Ardumower batteries in parallel and get more than 4 hours operation time.
very nice. for now , since we all already have it laid out, can we just keep the wire active for this very purpose for now , to be able to complete larger mow areas ?
ps. i wrote you also an email . long time ago, how did you do the rpm counting (for mow motor in your example) using the hall sensor A1302KUA ? that one is analogic.
i tried to put some resistors 4.7k and 10k from vcc to output and set it as digital..but no success for me maybe the magnet isnt strong enough ? i get about ~700 response on the analogic input with my 3x1mm neodymium magnet
@AlexanderG I was try docking but it does not work for me. I need the robot to back out from the docking house, but it wants to turn around and go forward out from the house but that is not possible. Where can I modify the code for docking?
I have fix mode. How do I enable only odometry and IMU?
Read carefully, maybe you missed one point (e.g. uploading modified map to the mower, and robot needs to touch the docking contacts, so show 'charge') ;-)
