charging station
xjust
does the current firmware knows to charge/resume operation using rtk gps ? in case the lawn is too big and battery runs out ?
Hello. Sunray firmware does not support automatic charge-and-resuming operation yet. I'm working on trying out RTK-based docking but it's complicated ... docking with float-only solution may work, but undocking with float-only solution can be tricky (if it should work cm-precise). But first experiments show it could work using odometry and IMU only. Currently, I'm using two Ardumower batteries in parallel and get more than 4 hours operation time.
Regards,
very nice. for now , since we all already have it laid out, can we just keep the wire active for this very purpose for now , to be able to complete larger mow areas ?
ps. i wrote you also an email . long time ago, how did you do the rpm counting (for mow motor in your example) using the hall sensor A1302KUA ? that one is analogic.
i tried to put some resistors 4.7k and 10k from vcc to output and set it as digital..but no success for me :) maybe the magnet isnt strong enough ? i get about ~700 response on the analogic input with my 3x1mm neodymium magnet
and for those who dont have the wire.. a very small loop that the robot detects easy using rtk.. then dock using it
@AlexanderG I was try docking but it does not work for me. I need the robot to back out from the docking house, but it wants to turn around and go forward out from the house but that is not possible. Where can I modify the code for docking?
I have fix mode. How do I enable only odometry and IMU?
Thx!
Hello, 'only odometry and IMU' is not supported in docking station (robot requires a GPS fix).
Have a look here:
Read carefully, maybe you missed one point (e.g. uploading modified map to the mower, and robot needs to touch the docking contacts, so show 'charge') ;-)
