So Startet mein M4 Board
16:23:33.902 -> SD card found!
16:23:33.902 -> RESET cause: power-on
16:23:33.902 -> Sunray,1.0.324
16:23:33.902 -> compiled for: Adafruit Grand Central
M4
16:23:33.902 -> using robot driver: AmRobotDriver
16:23:33.902 -> robot id: 5b:cd:5a:24:53:38:57:57:51:20:20:20:ff:08:1d:26
16:23:33.902 -> MOTOR_DRIVER_BRUSHLESS: yes
16:23:33.902 -> enableCharging 0
16:23:33.902 -> probing for HM-10 module (NOTE: will fail for
ESP32)...
16:23:33.902 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)9600...
16:23:34.413 -> BLE: AT
16:23:36.368 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)115200...
16:23:36.906 -> BLE: AT
16:23:36.906 -> OK
16:23:37.093 -> Bluetooth 4.0/BLE (HM-10) module found!
16:23:37.602 -> BLE: AT+VERSION
16:23:37.602 -> +VERSION=
ESP32 firmware V0.4.5,Bluetooth V4.0 LE
16:23:38.302 -> BLE: AT+NAMEArdumower
16:23:38.302 -> +NAME=Ardumower
16:23:38.984 -> BLE: AT+RESET
16:23:38.984 -> +RESET
16:23:39.215 -> RCModel disabled in config
16:23:39.215 -> using bumper driver: LiDAR
16:23:39.215 -> ENABLE_PASS
16:23:39.215 -> ENABLE_TILT_DETECTION
16:23:39.215 -> FREEWHEEL_IS_AT_BACKSIDE: 1
16:23:39.215 -> WHEEL_BASE_CM: 36
16:23:39.215 -> WHEEL_DIAMETER: 250
16:23:39.215 -> ENABLE_ODOMETRY_ERROR_DETECTION: 0
16:23:39.215 -> TICKS_PER_REVOLUTION: 650
16:23:39.215 -> MOTOR_DRIVER_BRUSHLESS
16:23:39.215 -> MOTOR_DRIVER_BRUSHLESS_MOW_DRV8308
16:23:39.215 -> MOTOR_DRIVER_BRUSHLESS_GEARS_DRV8308
16:23:39.215 -> MOTOR_FAULT_CURRENT: 6.00
16:23:39.215 -> MOTOR_OVERLOAD_CURRENT: 1.00
16:23:39.215 -> USE_LINEAR_SPEED_RAMP: 0
16:23:39.215 -> MOTOR_PID_KP: 2.00
16:23:39.215 -> MOTOR_PID_KI: 0.03
16:23:39.215 -> MOTOR_PID_KD: 0.03
16:23:39.215 -> MOW_FAULT_CURRENT: 8.00
16:23:39.215 -> MOW_OVERLOAD_CURRENT: 2.00
16:23:39.215 -> ENABLE_OVERLOAD_DETECTION: 1
16:23:39.215 -> ENABLE_FAULT_DETECTION: 1
16:23:39.215 -> ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
16:23:39.215 -> ENABLE_RPM_FAULT_DETECTION: 1
16:23:39.215 -> SONAR_INSTALLED
16:23:39.215 -> SONAR_ENABLE: 1
16:23:39.215 -> SONAR_TRIGGER_OBSTACLES: 1
16:23:39.215 -> RAIN_ENABLE: 0
16:23:39.215 -> BUMPER_ENABLE: 1
16:23:39.215 -> BUMPER_DEADTIME: 1000
16:23:39.215 -> BUMPER_TRIGGER_DELAY: 0
16:23:39.215 -> BUMPER_MAX_TRIGGER_TIME: 30
16:23:39.215 -> LIDAR_BUMPER_ENABLE: 0
16:23:39.215 -> CURRENT_FACTOR: 1.98
16:23:39.215 -> GO_HOME_VOLTAGE: 21.50
16:23:39.215 -> BAT_FULL_VOLTAGE: 28.70
16:23:39.215 -> BAT_FULL_CURRENT: 0.20
16:23:39.215 -> BAT_SWITCH_OFF_IDLE: 0
16:23:39.215 -> BAT_SWITCH_OFF_UNDERVOLTAGE: 1
16:23:39.215 -> GPS_USE_SKYTRAQ
16:23:39.215 -> REQUIRE_VALID_GPS: 1
16:23:39.215 -> GPS_SPEED_DETECTION: 1
16:23:39.215 -> GPS_MOTION_DETECTION: 1
16:23:39.215 -> GPS_REBOOT_RECOVERY: 1
16:23:39.215 -> GPS_CONFIG: 1
16:23:39.215 -> GPS_CONFIG_FILTER: 1
16:23:39.215 -> CPG_CONFIG_FILTER_MINELEV: 10
16:23:39.215 -> CPG_CONFIG_FILTER_NCNOTHRS: 10
16:23:39.215 -> CPG_CONFIG_FILTER_CNOTHRS: 30
16:23:39.215 -> ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
16:23:39.215 -> OBSTACLE_DETECTION_ROTATION: 0
16:23:39.215 -> KIDNAP_DETECT: 1
16:23:39.215 -> KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
16:23:39.215 -> DOCKING_STATION: 0
16:23:39.215 -> DOCK_IGNORE_GPS: 0
16:23:39.215 -> DOCK_AUTO_START: 1
16:23:39.215 -> TARGET_REACHED_TOLERANCE: 0.10
16:23:39.215 -> STANLEY_CONTROL_P_NORMAL: 3.00
16:23:39.215 -> STANLEY_CONTROL_K_NORMAL: 1.00
16:23:39.215 -> STANLEY_CONTROL_P_SLOW: 3.00
16:23:39.215 -> STANLEY_CONTROL_K_SLOW: 0.10
16:23:39.215 -> BUTTON_CONTROL: 1
16:23:39.215 -> USE_TEMP_SENSOR: 0
16:23:39.215 -> BUZZER_ENABLE
16:23:39.215 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
16:23:39.215 -> -----------------------------------------------------
16:23:39.215 -> SKYTRAQ::begin serial
16:23:39.215 -> using gps driver: SKYTRAQ
16:23:39.215 -> using skytraq gps...
16:23:39.215 -> Map::begin
16:23:39.215 -> sizeof Point=4
16:23:39.215 -> map load... no map file!
16:23:39.215 -> map dump - mapCRC=0
16:23:39.215 -> points:
16:23:39.215 -> perimeter pts: 0
16:23:39.215 -> exclusion pts: 0
16:23:39.215 -> exclusions: 0
16:23:39.215 -> dock pts: 0
16:23:39.215 -> mow pts: 0
16:23:39.215 -> free pts: 0
16:23:39.215 -> mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3
16:23:39.215 -> probing for ESP8266 (NOTE: will fail for
ESP32)...
16:23:39.727 -> WIFI (ESP8266) not found! If you have ESP8266 and the problem persist, you may need to flash your ESP to firmware 2.2.168
16:23:39.727 -> MPU6050/9150 found
16:23:39.727 -> using imu driver: MpuDriver
16:23:41.030 -> resuming is activated
16:23:41.030 -> state load... ok
16:23:41.075 -> dumpState: X=0.00 Y=0.00 delta=0.18 mapCRC=0 mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=4 op=0 sensor=9 sonar.enabled=1 fixTimeout=100 absolutePosSource=0 lon=0.00 lat=0.00 pwmMaxMow=255 finishAndRestart=0 motorMowForwardSet=1
16:23:41.075 -> timetable (UTC times) 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23
16:23:41.075 -> timetable (UTC times) mon * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) tue * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) wed * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) thu * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) fri * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) sat * * * * * * * * * * *
16:23:41.075 -> timetable (UTC times) sun * * * * * * * * * * *
16:23:41.075 -> * means mowing allowed
16:23:41.075 -> current GPS UTC weektime: dayOfWeek=mon hour=0
16:23:41.075 -> timetable enabled: 0
16:23:41.075 -> mowing allowed: 1
16:23:41.075 -> Error:
motor driver right signaled fault
16:23:41.158 -> batTemp=998 cpuTemp=33
16:23:41.158 -> GPS time (UTC): dayOfWeek=sun hour=0
16:23:41.158 -> AUTOSTOP: timetable is disabled
16:23:41.158 -> AUTOSTART: not defined DOCKING_STATION
16:23:41.158 -> ==> changeOp:ImuCalibration(initiatedByOperator 0)->Idle
16:23:41.158 -> IMU gyro calibration (robot must be static)... 1
16:23:41.158 -> sending encryptMode=1 encryptChallenge=155
16:23:41.158 -> 0:0:9 ctlDur=0.00 op=ImuCalibration(initiatedByOperator 0)->Idle freem=237587 sp=20000084 bat=0.00,0.000(0.00) chg=0.00,0(0.00) diff=0.000 tg=0.00,0.00 x=0.00 y=0.00 delta=0.18 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=9.15
16:23:42.018 -> WARNING - LoopTime: 3 min=2 mean=7.41 max=9146
16:23:42.098 ->
motor fault recover counter 1
16:23:42.183 -> Error:
motor driver left signaled fault
16:23:42.183 -> IMU gyro calibration (robot must be static)... 2
16:23:43.066 -> charger conn=0 chgEnabled=0 chgTime=0 charger: 0.02 V 0.00 A bat: 27.71 V diffV=-0.28 slope(v/min)=0.00 slopeLowCounter=1
16:23:43.205 -> IMU gyro calibration (robot must be static)... 3
16:23:43.205 ->
motor fault recover counter 2
16:23:43.250 -> Error:
16:23:44.188 -> IMU gyro calibration (robot must be static)... 4
16:23:44.268 ->
motor fault recover counter 3
16:23:44.355 -> Error:
16:23:45.197 -> IMU gyro calibration (robot must be static)... 5
16:23:45.380 ->
motor fault recover counter 4
16:23:45.427 -> Error:
16:23:46.190 -> 0:0:14 ctlDur=0.02 op=ImuCalibration(initiatedByOperator 0)->Idle freem=237483 sp=20000084 bat=27.72,0.000(0.18) chg=0.16,0(0.01) diff=-12.487 tg=0.00,0.00 x=0.00 y=0.00 delta=0.18 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=14.15
16:23:46.236 -> IMU gyro calibration (robot must be static)... 6
16:23:46.468 ->
motor fault recover counter 5
16:23:46.515 -> Error:
16:23:47.260 -> IMU gyro calibration (robot must be static)... 7
16:23:47.568 ->
motor fault recover counter 6
16:23:47.614 -> Error:
16:23:48.267 -> IMU gyro calibration (robot must be static)... 8
16:23:48.637 ->
motor fault recover counter 7
16:23:48.684 -> Error:
16:23:49.240 -> IMU gyro calibration (robot must be static)... 9
16:23:49.724 ->
motor fault recover counter 8
16:23:49.755 -> Error:
16:23:50.250 -> IMU gyro calibration (robot must be static)... 10
16:23:50.828 ->
motor fault recover counter 9
16:23:50.875 -> Error:
16:23:51.142 -> 0:0:19 ctlDur=0.02 op=ImuCalibration(initiatedByOperator 0)->Idle freem=237483 sp=20000084 bat=27.74,0.000(0.28) chg=0.16,0(0.01) diff=-21.883 tg=0.00,0.00 x=0.00 y=0.00 delta=0.18 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=19.15
16:23:51.279 -> IMU gyro calibration (robot must be static)... 11
16:23:51.876 ->
motor fault recover counter 10
16:23:51.876 -> ERROR:
motor recovery failed
16:23:51.944 -> Error:
16:23:52.038 -> Info - LoopTime(ms) now=3 min=2 mean=2.88 max=8
16:23:52.316 -> IMU gyro calibration (robot must be static)... 12
16:23:53.010 ->
16:23:53.056 -> Error:
16:23:53.282 -> IMU gyro calibration (robot must be static)... 13
16:23:54.052 ->
16:23:54.139 -> Error:
16:23:54.325 -> IMU gyro calibration (robot must be static)... 14
16:23:55.181 ->
16:23:55.213 -> Error:
16:23:55.302 -> IMU gyro calibration (robot must be static)... 15
