Hi
As already discused with Alex,Markus and Sven I start this new topic
Enclosed you will find a schematic of the actual ardumower setup as far i could find out (please correct me)
I used labels in the schematic so that i can easily change pins to simplify the PCB layout later
First i will make a simple shield for my needs (RL500) and little by little at sensors
I'm thinking of making the shield a bit bigger than the arduino, so that ground and +5V will be the outside of the board
All sensors/switches/modules will have headers on the board with all signals,+5v and ground
Integrated on the board the HC05 bluetooth module, MC33926 module,DC DC converter (thanks Marksu) buzzer,button, and led
etc...
my goal is to make a single side PCB that you can build yourself the "good old way"
the following will be external of the board:
- The perimeter sensor and amplifier
- Fuse on battery
- Schottky diode for charging
- charge current sensor
- drive motor H-bridge (except if you use the dual MC33926 module)
- mowmotor H-bridge
- drive motor currentsensor (except if you use the dual MC33926 module)
- mowmotor current sensor
Have a look at the schematic and correct me please
Walter
etc...
- Fuse on battery
- mowmotor H-bridge
Walter
