In the past i did exactly the same as you and increase the max
motor power but its A VERY BAD IDEA. I finally destroy the
Motor Driver :woohoo:
Normaly you have 3 stages on power management 2 are softwares (Pfod setting
motor max power) ,at 80% to start the spirale and 100% to stop for 1 minute the
motor and restart automaticly .
You need to see this behaviour before the last stage.
The last stage it's better to
never go in it, It's the driver error itself and need a full restart of the mower.
So better to use a big thermal mower for the first mowing of the season and after leave the robot only cut some cm each day in auto mode.
In the code , accel of the
motor (during the 2 start second) sometime we don't read the power to avoid stop on sense peak ,but again it's very dangerous if the blade is stop by piece of wood for example ,it can after 20 automatic starting try : destroy
motor or driver.
For a long life of the driver and
motor ,try to find the correct Max power to avoid hardware protection (Same for drive
motor)
