Good morning,
Yesterday I set to assemble the recently acquired (at marotronics) ardumower chassis and, though most of the process is straitghtforward, still a couple doubts remain, namely:
1) The front underrun protection has two holes near its centre, what are these used for?
2) The four extra large chassis bolts, I take, are to be used to attach both underrun protections (front and rear) to the underside of the robot, but said bolts should not be screwed in all the way (the underrun protections would then sit too high above the ground and would not perform well, right?). Then some sort of separator should be provided to keep the protections from moving up and down, but these are not included in the kit, hence my doubt; are the separators needed? Are they just advisable? What are you people using as separators?
Thanks in advance for you help.
