According other discussion , I post here a description of the possible mowing speed of Sunray firmware .
On Robomow RL1000 platform using 3 mow motor and standard code (mowing width of 53 cm) but setting mapping compute to 45 cm it's possible to mow near 400 m2 / hour
here the screen copy of the Statistique result on 57 min mowing on 387 m2 ,so 407m2/h
THe video result is here:
And here the same mowing area on different PCB teensy 4.1 version describe here :
Code is adjust in the angular and linear speed for more smooth movement:
Area is mow in 51 min ,so it's 455 m2/h
And the video result :
SUNRAY on Teensy PCB
Here the link to sunray version for TEENSY PCB and robomow RL1000 platform. It's Visual studio code : https://github.com/Boilevin/Sunray_TeensyPcb Connection of the RTK board is at Serial5 on PCB other part are the same as perimeter version. And the result in video:
www.diy-robot-lawn-mower.com
