Evothings Viewer App is a web browser with some integrated (Javascript) plugins for hardware access (Bluetooth BLE etc.). This article describes how to build the Evothings Viewer App for Android (or CGTek Viewer for iOS) from code using Ubuntu Linux 18.04.
NOTE: If you have difficulties to get 'EvothingsViewer' running on your phone etc., I have uploaded the same app (based on the public Evothings Viewer code), just under another name and for the latest Android devices (SDK) at Google Play: https://play.google.com/store/apps/details?id=de.grauonline.evothingsviewer
Maybe give it a try... Tip: if the App is crashing after installation/upgrade, delete the 'location permissions' in Android App settings and restart the App.
Evothings Viewer is based on Apache Cordova (https://cordova.apache.org/).
- Install Android SDK: https://developer.android.com/studio/install
In Android Studio->SDK Manager, install Android SDK 27 and Android build tools
- Install OpenJDK 1.8 (Java8): sudo apt-get install -y openjdk-8-jdk
Activate OpenJDK 1.8 (Java8) compiler: sudo update-alternatives --config javac
- Install NodeJS on your Ubuntu Linux computer (I'm using NodeJS 14.15.0 and NPM 6.14.8):
sudo apt install nodejs
or: https://nodejs.org/en/download
- Install Cordova using NodeJS module manager:
sudo npm install -g cordova
or a specific Cordova version (not recommended) with:
sudo npm uninstall cordova -g
sudo npm install -g cordova@8.0.0
- Verify Cordova is properly installed (should output version 8.0.0 or higher, I have tested it with 11.1.0):
cordova -v
- Optional: verify SSH for Git is properly configured (if git is not working in the next step, add your SSH public key to Github):
https://docs.github.com/en/authentication/troubleshooting-ssh/error-permission-denied-publickey
- Download 'Evothings Viewer code (for Android)':
git clone git@github.com:evothings/evothings-viewer.git
or 'CGTek Viewer (for iOS)':
git clone https://github.com/sjrcgtek/cgtek-viewer
- Install missing NodeJS packages using NodeJS package manager:
cd evothings-viewer
(NOTE: if you get an error about config-plugin, edit file 'package.json' and correct the dependency import like this:
"com.evothings.evothingsviewer.config-plugin": "file:config/config-plugin"
...and remove the line starting with "config-plugin": )
npm install
optional (if you get vulnerabilities): npm audit fix --force
If you get an error like 'Using requireCordovaModule to load non-cordova module elementtree is not supported', edit file 'scripts/util.js' and replace the lines with 'requireCordovaModule('elementtree') like this: require('elementtree')
- Build using Cordova:
cordova platform add android
cordova build android
- Run it in phone emulator (you will have to install it in Android Studio before):
cordova run --emulator
or on a real device: cordova run android
(you can list devices with 'adb devices', you have to enable developer mode on your phone - more details here: https://cordova.apache.org/docs/en/2.9.0/guide/getting-started/android/)
- To make a bundle for GooglePlay, first remove plugins:
cordova plugin remove phonegap-plugin-barcodescanner
cordova plugin remove com.unarin.cordova.beacon
cordova plugin remove phonegap-nfc
cordova plugin remove cordova-plugin-local-notification
- Modify the config.xml like this:
<platform name="android">
<edit-config file="app/src/main/AndroidManifest.xml" mode="merge" target="/manifest/application/activity[@android:name='MainActivity']" xmlns:android="http://schemas.android.com/apk/res/android">
<activity android:exported="true"/>
</edit-config>
<edit-config file="app/src/main/AndroidManifest.xml" mode="merge" target="/manifest/application" xmlns:android="http://schemas.android.com/apk/res/android">
<application android:usesCleartextTraffic="true"/>
</edit-config>
- Finally make a bundle and sign it like this:
cordova build android --prod --release
cd platforms/android && ./gradlew bundle && cd ../..
APP=platforms/android/app/build/outputs/bundle/release/app.aab
jarsigner -verbose -sigalg SHA256withRSA -digestalg SHA-256 -keystore ../keys/evothings.jks $APP evothings
jarsigner -verify -verbose $APP
zipalign -v 4 $APP ./EvothingsViewer.apk
- Tip: If the App crashes, you can activate Android developer mode and then find a new menu item 'generate crash report' on your phone (Android settings->System->Developer Options->Generate crash report) (https://academy.test.io/en/articles/2541912-crash-logs-on-mobile-devices#h_7b23c4a3aa, https://www.browserstack.com/guide/how-to-get-android-app-crash-logs, https://support.kaspersky.com/de/common/diagnostics/13048)
