Signal occasionally reads outside while moving.
jonathanbyrn
When I am mowing the signal will momentarily jump from inside to outside, eg, from -50 to + 30 for a second and then back to -50 again. I have tested the connections and they are all fine. I have run the motors separately and the signal stays fixed. Is there anything else that could be causing it or is there a way to turn down the sensitivity?
It depends on the situation. But I think your perimeter signal is to low. It could be that the mow motors disturb the coils. Or the coils are to near at the motors. Or your coil is to far from the amplifier. Or you have a ground loop.
Some pictures would be nice.
Thanks for getting back to me. I have attached some images. I soldered the coil directly onto the board but there is still a bit of metal between the coil and the board.
I ran the test again today for longer today with the robot raised so there should be no change in signal magnitude. The right motor made no difference after 10 minutes, but twice while testing the left motor, the signal momentarily spiked to outside.
I checked where the connecting wires are running to the pcb and it is as direct as possible. What is the best way of insulating against motor noise and do I have to insulate the connecting wires as well?
Attachment: https://forum.ardumower.de/data/media/kunena/attachments/3979/IMG_20170624_102049.jpg/
I think you don't need the black gnd calbe, if you have connected gnd to the green plug. Therfore it could be, that you get a gnd loop.
Take a look at that (maybe with google translator): http://www.ardumower.de/index.php/d...-schwaches-perimetersignal?limitstart=0#12089
Anyway the other things looks fine. is the cable shieldes inside the mower?
How big is the magnitude?
For shielding look here: http://www.ardumower.de/index.php/d...der-receiver-few-questions?limitstart=0#12141 http://www.ardumower.de/index.php/de/forum/schleifensensoren-generator/1212-schwaches-perimetersignal?start=20#12456
The cables inside the main box are not shielded.
The magnitude ranges from 700/500 close to the perimieter to 30 at the furthest distance. The resistance on the wires is 12 ohm. I tried adjusting the pots on the perimeter fence but nothing seemed to happen. Is there another way of adjusting the strength.
Thanks for the links. I was going try tin foil but I think I have a sheet of aluminium somewhere. I will try that.
Thanks again for getting back to me so quickly!
The pots are not used.
You should try to get a magnitude of 1500-1900 15cm away from perimeter on the inside for example. Thats what I read here in the forum. I use my own system, therfore I am not sure.
I think the resistent of the wire is very high. How long is it? I have 2Ohm for 230m .
Do you have a resistor serial to the wire? What is the Voltage of the sender DC/DC converter?
Do you mean wires or wire? If wires please explain the plural.
Do you get the same amplitude using motors on compared to motors of?
If I get very close to the wire it reads 1000 but nothing like 1500. I could tweak the DC-DC board to increase the voltage.
It is a 200 meter wire. Each 100 is approx 3 ohm resistant and I have a 10 ohm resistor. The total resistance is 16 ohms.
I have 4 wires coming from the coil connecting to the PCB
Yes, it stays the same and then there is a momentary outside reading and then it goes back to the same reading.
I have manufactured two steel sheets that I will test as the insulation. I will let you know how I get on.
You mentioned I can remove one of the grounds. Is that the one shown in the attached image?
Attachment: https://forum.ardumower.de/data/media/kunena/attachments/3979/InkedIMG_20170624_102049_LI.jpg/
Hi Johnathtan
Yes not use on fence but On your receiver what is the position of the Pot , did you bridge the capacitor ?
The 2 GND are connected on my receiver and i can read 2064 on maxi MAG at 10CM upper the wire and 5CM on the left, the value on the sender are exactly the same as in the WIKI.
Last think i have a problem with the 2 first coil i received from shop (Maybe my fault when solder) so if you have another coil please try it and be carrefull to not overheat the wire when solder or first try with screw.
By.
Attachment: https://forum.ardumower.de/data/media/kunena/attachments/3545/receiver1.jpg/
I added a piece of steel (see picture) and it is still generating an occasional negative signal. I think it might be something else other than electrical interference.
I rechecked the resistance on the loop, it is 14 ohms. I measured the strength at 60cm distance from the perimeter wire. It was between -240 and -265 at 6.5V. I increased the voltage on the perimeter sender from 6.5 to 7.5 and the signal oscillated between -280 and -320. I then increased the voltage to 8.5V but it didn't make a change to the signal.
I soldered the positive as the connector looked as it could be coming loose, I hope I didn't damage the coil!
I disconnected the ground on the front and the signal remained the same. I didn't bridge the two grounds at the front. I will have to check continuity tomorrow.
I didn't add a capacitor to the circuit as the diagram said to leave it out. Is there actually a capacitor on the board I need to bridge?
Attachment: https://forum.ardumower.de/data/media/kunena/attachments/3979/IMG_20170625_143309.jpg/
Ahh, I didn't notice the red line on the diagram! I thought it was a capacitor added to the circuit. I will bridge it tomorrow. Thanks for the advice!
Hi Jonathan.
On the amplifier.
Yes you need to bridge the capacitor (like on the picture 3 i have posted before) and as Alda say put the poti to the maximum.
By.
It finally stopped raining and I got to test it again. I have bridged the amplifier and the POT on the mower is at max. While the signal is higher close to the fence (600-700) It drops off quickly the further away from it. In the middle of the garden it goes as low as 10 / -10. Is there any way to boost it further or could this be damage to the coil itself?
Hi .
It's strange maybe try with a 20 ml wire on the sender.
Verify at the output of the receiver you need to have 2.5 volt .
Verify also when you make the Adc calibration the value for the receiver (AD5 I THINK) is between 400 and 600 or not ? (Half of 1024=5Volt)
By
OK,
what you can do is place mower on the desk and switch on power, but NO start for sure, but you can connect via pfod app on the mower.
Than you can make a short (1m) wire loop with 10ohm resistor and set 8V for sender = 0,8A into wire. Than you can easily move with wire around coil and via pfod and perimeter menu read a value. Please send us a maximal readed value. Before please make a ADC calibration with sender OFF.
Normaly when sender is OFF readed value must oscilate around zero aprox +-20.
Alex
