max@birley_com
Hi
I am just getting into this ardumower project. It looks exciting. At first I will use an arduino megga. When I understand the project better I will move to the PCB. For now, I have a sabertooth 2X12 motor controller. I have used it successfully before on a chassis controlled by a botboarduino and also by RC radio controll. The sabertooth has 2 servo type leads to control the 2 motors. It does not have IN1,IN2,IN3,IN4,ENA,ENB connections on the board that the ardumower code is expecting. Can anyone help me to change the code to use this motor driver. The main reason I want to stick with Sabertooth is that I am working on another project and it has a larger 2X32A motor controller and I would like to stay with one brand. If this will be too difficult then I will have to use the recommended parts. Your help will be welcome
Regards
Max
Regards
Max
