max@birley_com
Hi All
What is the large relay located near the 2 fuses used for....is it for controlling the charging of the battery.
How can I test to see if it is working. Currently nothing I am doing is triggering it. (Note I am using a 24v board with a 12 v supply) with battery monitoring turned off.
Also the 3 user defined switches located on pin40. What current can they take? What are they typically used for....lights, buzzers ?????
lastly does the tilt sensor located on P19 work differently from the tilt that the IMU will detect and if so how
regards
Max
regards
Max
