Starsurfer78
At the moment i test DUE and the Raspberry (4) and set up the Raspberry according to the Wiki.
At the Point:
As shown on the photo in the wiki.
The Power LED from DUE is on and the L (orange) LED is blinking.
THE DUE is empty.
Do i forgot something?
At the Point:
the Phyton Console show the Error:Piardu need to start and you can navigate inside all the menu very slowly if there are no firmware in the arduino DUE so wait
The PI and the DUE are connected with a USB cable and a 5" Touchscreen connected only with HDMI and a USB Cable for the Touch.>>>
============= RESTART: /home/pi/Documents/PiArdumower/PiArdu.py =============
Linux Platform
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
ERREUR DE CONNECTION WITH PCB1.3 DUE
RFID file loaded OK
File "/home/pi/Documents/PiArdumower/PiArdu.py", line 609, in checkSerial
mymower.dueSerialReceived=Due_Serial.readline()
NameError: name 'Due_Serial' is not defined
*** extract_tb:
[<FrameSummary file /home/pi/Documents/PiArdumower/PiArdu.py, line 609 in checkSerial>]
*** format_tb:
[' File "/home/pi/Documents/PiArdumower/PiArdu.py", line 609, in checkSerial\n mymower.dueSerialReceived=Due_Serial.readline()\n']
*** tb_lineno: 609
ERROR PLEASE CHECK TRACEBACK INFO
Exception in Tkinter callback
File "/usr/lib/python3.7/tkinter/__init__.py", line 1705, in __call__
return self.func(*args)
File "/home/pi/Documents/PiArdumower/PiArdu.py", line 208, in ButtonFlashDue_click
Due_Serial.close()
THE DUE is empty.
