Pfod How to prog
bernard
Well-known member
Hi
Here small explanation to add Something in Pfod :
For example in rain menu:
void RemoteControl::sendRainMenu(boolean update) {
  if (update) serialPort->print("{:"); else serialPort->print(F("{.Rain`1000"));
  serialPort->print(F("|m00~Rain Use "));
  sendYesNo(robot->rainUse);
  serialPort->print(F("|m01~Counter "));
  serialPort->print(robot->rainCounter);
  serialPort->println(F("|m02~Value"));
  serialPort->print(robot->rain);
  serialPort->println(F("|m03~DHT22 Use "));
  sendYesNo(robot->DHT22Use);
  serialPort->println(F("|m04~Temperature "));
  serialPort->print(robot->temperatureDht);
  serialPort->println(F("|m05~Humidity "));
  serialPort->print(robot->humidityDht);
  sendSlider("m06", F("Maximum Temperature"), robot->maxTemperature, "", 1 ,80, 1);
  serialPort->println("}");
void RemoteControl::processRainMenu(String pfodCmd) {
  if (pfodCmd == "m00") robot->rainUse = !robot->rainUse;
  else if (pfodCmd == "m03") robot->DHT22Use = !robot->DHT22Use;
  else if (pfodCmd.startsWith("m06")) processSlider(pfodCmd, robot->maxTemperature, 1);
  sendRainMenu(true);
As you can see 2 parts:
sendRainMenu
is call to print the data, 1000 is the refresh rate.
The first digit on "m00" descibe the menu itself (rain here) the 2 others digit are use to reference the text,SendYesNo or slider you print and is different on each new object
:processRainMenu
is call when you change Something with the phone
If you click on Rain Use : if (pfodCmd == "m00") is call and the variable robot->rainUse is switch from Yes to No or opposite.
m01 is only print value so if you click on raincounter nothing is call in processRainMenu.
m06 is a slider so sendSlider("m06", F("Maximum Temperature"), robot->maxTemperature, "", 1 ,80, 1); is used to print it
F("Maximum Temperature") is the text you see on your phone.
robot->maxTemperature is the value of the slider.
1 ,80, 1 are minimum,maximum and step (i don't remember the exact order and maybe strange between Pfod and Arduremote on negative value ??).
When you click on the slider:
is call and the robot maxTemperature is change.
So to add a slider
First use Ctrl F on ide to be sure the "m07" is not use.
Into sendRainMenu add
sendSlider("m07", F("New slider"), robot->oneRobotExistingVar, "", 1 ,255, 1);
and into processRainMenu
else if (pfodCmd.startsWith("m07")) processSlider(pfodCmd, robot->sameRobotExistingVar, 1);
To add simple text follow by a value
Into sendRainMenu add:
serialPort->println(F("|m08~My Text "));
 serialPort->print(robot->oneRobotExistingVar);
To add a yes/No button
serialPort->print(F("|m09~Toggle button "));
  sendYesNo(robot->oneRobotExistingVar);
and into processRainMenu add:
else if (pfodCmd == "m09") robot->oneRobotExistingVar = !robot->oneRobotExistingVar;
Hope it can help !
