That's a quite an open guestion, but assuming it's for the default ardumower case and build.. I can see at least few issues, the current odometries have only 4 pins and this one seems to be using 3 channels, ground and +5v so I think you would need 5 pins for the board. Also you will most likely need to do your own mounts to the default case, it looks completely different to the current motors with encoders. But then again, if you would be using default case you would propably also have the default motors which already have the encoders/odometries. And as it is 3 channels of data instead of 2, I'm sure it will involve some code work also.
I'm sure anything is possible, but maybe someone with more expertise can shed some ligth on this.
