No serial output when GrandCentral M4 is on PCB 1.4
mihaha
Hello,
I am trying to run Sunray PCB 1.4 with the GrandCentral M4 board. I got the latest 1.0.298 release code and downgraded 'Adafruit SAMD Boards' version to 1.7.5. Bootloader is v3.14.0
Then I configured and compiled it without errors and uploaded it to the GrandCentral board. When I reset the board and have it running on its own (without connecting it to the main ardumower board), it appears to be running fine and I see logs in the serial console. So far, so good.
When I add the GrandCentral to the Ardumower board and have it USB connected to my laptop, I don't see any messages in the Arduino IDE serial console anymore.
With the battery on, I see all 7 leds on ardumower are on, so I guess power supply is ok.
I have the DC/DC convertor, the relay, RTC, capacitors, diodes and MOSFET, the buzzer, the ESP32(led is also on) and the motor drivers(motors not connected)
Jumpers - JP1, JP8=Dauer ON, JP4=5V, JP10=3.3V
I haven't connected the IMU yet.
The buzzer doesn't make single sound, if this is a clue.
I'm a bit lost here, so if you have ideas what I might be missing or doing wrong or how I can troubleshoot and make it write to the serial console, please let me know
Did you bridged two jumpers on the backside?
Maybe you could see logs if you connect an SD memory and activate the logs in the configuration of the arduino code (config.h):
#define ENABLE_SD 1 // enable SD card services (resuming, logging)? (uncomment to activate)
#define ENABLE_SD_LOG 1 // enable SD card logging? uncomment to activate (not recommended - WARNING: may slow down system!)
#define ENABLE_SD_RESUME 1 // enable SD card map load/resume on reset? (uncomment to activate)
Greetings.
Löte diese zwei Widerstände ein, dann funktioniert die1679479810521.jpegserielle Ausgabe auch wenn der M4 auf dem PCB aufgesteckt ist.
I use 115200 baud rate as described for the M4 - https://learn.adafruit.com/adafruit-grand-central/advanced-serial-console-on-windows. It works well when the code logs ok on the M4, just not when plugged on the main ardumower board..
Maybe a bit unrelated but I figured I got the buzzer on the wrong location so maybe this is why it makes no sound. I'm going to play with the board a bit more next week and if I can't figure out what's going on, I'll try the SD card logging option and will write later
@Hartmut, can you give me a bit more details about these resistors:
- What Ohms are they?
- Which M4 pins have you connected? (I don't see clearly from the image)
If this is mentioned somewhere in the Sunray wiki, just send me a link or point me to the right reference
(PS - I used to study German at school quite some years ago but never got to speak it fluently, so I'll stick to writing in English here )
Thakns for the suggestions, guys!
Into wiki under Grand central M4:
2 pull up resistor 2.2K
Just setting up a mower with PCB 1.4 and the Grand Central M4, observed similar behavior: If I flash the firmware via USB, then I do see logs in the Arduino IDE just fine.
Once I reset the M4 then I don't see the logs in the Arduino IDE anymore.
Stupid question, but did you reopen the console after flashing successfully finished?
From your description, i think the board is not starting after reset. I have a weird behaviour, sometimes i need to push the start switch 2- 3 times, or even cut the power and push the startswitch again before it starts. Also, Start first and wait a few secs before connecting USB. Don´t plug in USB before starting the board.
