17:21:17.462 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
17:21:17.462 -> configsip: 0, SPIWP:0xee
17:21:17.462 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
17:21:17.462 -> mode:DIO, clock div:1
17:21:17.462 -> load:0x3fff0018,len:4
17:21:17.462 -> load:0x3fff001c,len:1216
17:21:17.462 -> ho 0 tail 12 room 4
17:21:17.462 -> load:0x40078000,len:9720
17:21:17.503 -> load:0x40080400,len:6352
17:21:17.503 -> entry 0x400806b8
17:21:17.868 -> ESP32 firmware V0.4.5,Bluetooth V4.0 LE
17:21:17.868 -> Configuring WDT...
17:21:17.868 -> starting BLE...
17:21:18.094 -> using NimBLE library
17:21:18.094 -> Waiting a BLE client connection to notify...
17:21:18.094 -> 289 ping
17:21:18.608 -> Attempting to connect to WPA SSID: BusinessTurtle
17:21:18.608 -> using static IP
17:21:18.981 -> You're connected with SSID=BusinessTurtle and IP=10.0.0.67
17:21:18.981 -> Default Memory: free size: 132608 bytes largest free block: 113792
17:21:18.981 -> Internal 8bit Memory: free size: 132608 bytes largest free block: 113792
17:21:18.981 -> starting HTTP server
17:21:20.100 -> 2290 ping
17:21:22.112 -> 4291 ping
17:21:24.103 -> 6292 ping
17:21:26.129 -> 8293 ping
17:21:28.096 -> 10294 ping
17:21:30.104 -> 12295 ping
17:21:32.118 -> 14296 ping
17:21:34.125 -> 16297 ping
17:21:36.099 -> 18298 ping
17:21:38.137 -> 20299 ping
17:21:40.130 -> 22300 ping
17:21:42.134 -> 24301 ping
17:21:44.136 -> 26302 ping
17:21:46.126 -> 28303 ping
17:21:48.126 -> 30304 ping
17:21:50.134 -> 32305 ping
17:21:52.115 -> 34306 ping
17:21:54.132 -> 36307 ping
17:21:56.123 -> 38308 ping
17:21:58.134 -> 40309 ping
17:22:00.142 -> 42310 ping
17:22:02.128 -> 44311 ping
17:22:04.143 -> 46312 ping
17:22:06.116 -> 48313 ping
17:22:08.130 -> 50314 ping
17:22:10.130 -> 52317 ping
17:22:12.122 -> 54318 ping
17:22:14.125 -> 56319 ping
17:22:16.125 -> 58320 ping
17:22:18.124 -> 60321 ping
17:22:20.148 -> 62322 ping
17:22:22.127 -> 64323 ping
17:22:24.127 -> 66324 ping
17:22:26.128 -> 68325 ping
17:22:28.133 -> 70326 ping
17:22:30.155 -> 72327 ping
17:22:32.157 -> 74328 ping
17:22:34.161 -> 76329 ping
17:22:36.157 -> 78330 ping
17:22:38.159 -> 80333 ping
17:22:40.171 -> 82334 ping
17:22:42.145 -> 84335 ping
17:22:44.159 -> 86336 ping
17:22:46.175 -> 88337 ping
17:22:48.141 -> 90338 ping
17:22:50.141 -> 92339 ping
17:22:52.145 -> 94340 ping
17:22:54.152 -> 96341 ping
17:22:56.167 -> 98342 ping
17:22:58.168 -> 100343 ping
17:23:00.166 -> 102344 ping
17:23:02.178 -> 104345 ping
17:23:04.151 -> 106346 ping
17:23:06.179 -> 108347 ping
17:23:08.170 -> 110348 ping
17:23:10.176 -> 112353 ping
17:23:12.179 -> 114355 ping
17:23:14.182 -> 116356 ping
17:23:16.182 -> 118357 ping
17:23:18.195 -> 120358 ping
17:23:20.180 -> 122359 ping
17:23:22.164 -> 124360 ping
17:23:24.179 -> 126361 ping
17:23:26.166 -> 128362 ping
17:23:28.277 -> 130363 ping
17:23:30.196 -> 132364 ping
17:23:32.168 -> 134365 ping
17:23:34.175 -> 136369 ping
17:23:36.188 -> 138370 ping
17:23:38.197 -> 140372 ping
17:23:40.206 -> 142373 ping
17:23:42.180 -> 144374 ping
17:23:44.182 -> 146375 ping
17:23:46.184 -> 148376 ping
17:23:48.200 -> 150377 ping
17:23:50.192 -> 152379 ping
17:23:52.195 -> 154380 ping
17:23:54.191 -> 156381 ping
17:23:56.195 -> 158382 ping
17:23:58.197 -> 160383 ping
17:24:00.210 -> 162384 ping
17:24:02.217 -> 164385 ping
17:24:04.206 -> 166386 ping
17:24:06.212 -> 168387 ping
17:24:06.981 -> 169166 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+V,0x16
17:24:08.004 -> 170166 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+S,0x13
17:24:08.223 -> 170388 ping
17:24:08.988 -> 171166 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+T,0x14
17:24:10.214 -> 172389 ping
17:24:12.227 -> 174390 ping
17:24:13.006 -> 175167 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+V,0x16
17:24:14.005 -> 176166 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+S,0x13
17:24:14.195 -> 176391 ping
17:24:14.978 -> 177166 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮AT+T,0x14
17:24:16.233 -> 178392 ping
17:24:18.221 -> 180393 ping
17:24:18.993 -> 181165 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮6
17:24:20.005 -> 182166 UART rx: ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮13
17:24:20.228 -> 182394 ping
17:24:22.234 -> 184395 ping
17:24:24.212 -> 186396 ping
17:24:26.201 -> 188397 ping
17:24:28.216 -> 190398 ping
17:24:30.234 -> 192399 ping
17:24:32.228 -> 194400 ping
17:24:34.206 -> 196401 ping
17:24:36.215 -> 198402 ping
17:24:38.216 -> 200403 ping
17:24:40.229 -> 202404 ping
17:24:42.238 -> 204405 ping
17:24:44.216 -> 206407 ping
17:24:46.223 -> 208408 ping
17:24:48.236 -> 210409 ping
17:24:50.229 -> 212410 ping
17:24:52.244 -> 214411 ping
17:24:54.235 -> 216412 ping
17:24:56.252 -> 218413 ping
17:24:58.246 -> 220414 ping
17:25:00.222 -> 222415 ping
17:25:02.223 -> 224416 ping
17:25:04.252 -> 226417 ping
17:25:06.244 -> 228418 ping
17:25:08.241 -> 230419 ping
17:25:10.231 -> 232420 ping
17:25:12.246 -> 234421 ping
17:25:14.261 -> 236423 ping
17:25:16.261 -> 238424 ping
17:25:18.243 -> 240425 ping
17:25:20.260 -> 242426 ping
17:25:22.247 -> 244427 ping
17:25:24.266 -> 246428 ping
17:25:26.245 -> 248429 ping
17:25:28.302 -> 250430 ping
17:25:30.256 -> 252431 ping
17:25:32.238 -> 254432 ping
17:25:34.240 -> 256433 ping
17:25:36.241 -> 258434 ping
17:25:38.306 -> 260438 ping
17:25:40.250 -> 262439 ping
17:25:42.253 -> 264440 ping
17:25:44.259 -> 266441 ping
17:25:46.266 -> 268442 ping
17:25:48.274 -> 270443 ping
17:25:50.283 -> 272444 ping
17:25:52.278 -> 274445 ping
17:25:54.274 -> 276446 ping
17:25:56.262 -> 278447 ping
17:25:58.263 -> 280448 ping
17:26:00.268 -> 282449 ping
17:26:02.277 -> 284450 ping
17:26:04.266 -> 286455 ping
17:26:06.262 -> 288456 ping
17:26:08.278 -> 290457 ping
17:26:10.274 -> 292458 ping
17:26:12.300 -> 294459 ping
17:26:14.274 -> 296460 ping
17:26:16.271 -> 298461 ping
17:26:18.274 -> 300462 ping
17:26:20.290 -> 302463 ping
17:26:22.301 -> 304464 ping
17:26:24.283 -> 306465 ping
17:26:26.287 -> 308466 ping
17:26:28.289 -> 310467 ping
17:26:30.304 -> 312468 ping
17:26:32.307 -> 314469 ping
17:26:34.279 -> 316470 ping
17:26:36.310 -> 318471 ping
17:26:38.286 -> 320472 ping
17:26:40.307 -> 322473 ping
17:26:42.297 -> 324474 ping
17:26:44.289 -> 326475 ping
17:26:46.314 -> 328476 ping
17:26:48.294 -> 330477 ping
17:26:50.302 -> 332485 ping
17:26:52.303 -> 334486 ping
17:26:54.302 -> 336487 ping
17:26:56.298 -> 338488 ping
17:26:58.320 -> 340489 ping
17:27:00.317 -> 342490 ping
17:27:02.311 -> 344491 ping
17:27:04.321 -> 346492 ping
17:27:06.336 -> 348493 ping
17:27:08.302 -> 350494 ping
17:27:10.329 -> 352495 ping
17:27:12.530 -> 354715 ping
17:27:13.631 -> 355806 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮f⸮⸮l ⸮⸮⸮⸮=⸮⸮@8<=⸮⸮|x⸮??⸮⸮~⸮d 8⸮⸮⸮⸮?f⸮
17:27:14.003 -> 356177 UART rx:⸮⸮⸮⸮⸮⸮⸮ @⸮8&⸮⸮⸮<|⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮0 ?⸮⸮⸮⸮⸮⸮⸮ ?⸮⸮⸮⸮⸮⸮8⸮⸮⸮⸮⸮⸮⸮⸮ ⸮ ~⸮P⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
17:27:14.003 -> ⸮⸮⸮⸮⸮⸮4`⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮|⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮+⸮⸮0⸮⸮⸮⸮p8?⸮⸮⸮⸮⸮⸮⸮<⸮⸮⸮⸮?⸮⸮ѿ⸮⸮6⸮⸮⸮⸮⸮⸮⸮⸮0X⸮⸮⸮⸮@⸮@⸮`⸮⸮8⸮⸮⸮⸮⸮⸮⸮T+S,0x13
17:27:14.553 -> 356716 ping
17:27:16.523 -> 358717 ping
17:27:18.548 -> 360718 ping
17:27:20.543 -> 362719 ping
17:27:22.536 -> 364720 ping
17:27:24.553 -> 366721 ping
17:27:26.563 -> 368722 ping
17:27:28.531 -> 370723 ping
17:27:29.688 -> 371855 UART rx:⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮|⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮~⸮@@⸮⸮~⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮hx⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@X⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ `08H⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮|⸮⸮ ⸮[⸮⸮⸮⸮:<<|⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮ ⸮⸮⸮x⸮?⸮⸮⸮⸮⸮⸮?⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮/⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮0~0⸮⸮⸮⸮|⸮⸮⸮⸮/h0⸮⸮⸮|⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮/⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮x⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮?⸮⸮⸮⸮⸮⸮~⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮,x⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮2⸮⸮p⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮@⸮⸮⸮4⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮h⸮⸮⸮>@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
17:27:30.565 -> 372724 ping
17:27:32.564 -> 374725 ping
17:27:34.548 -> 376726 ping
17:27:36.560 -> 378727 ping
17:27:38.562 -> 380728 ping
17:27:40.560 -> 382729 ping
17:27:42.560 -> 384730 ping
17:27:44.544 -> 386731 ping
17:27:46.555 -> 388732 ping
17:27:48.542 -> 390733 ping
17:27:50.577 -> 392734 ping
17:27:52.566 -> 394735 ping
