Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Hello,
I recently build the sender, I am using a 12 ohm resistor in the loop. Both the resister and the power supply of the sender get very hot. Is this normal?
Thanks,
Tim
Hello, did you set the transmitter as described in the wiki? how is the total resistance from your bow? how much watt is the resistance? that the resistance warms up well can be normal. vg thorsten
Should be normal. My resistor is very hot too ( and I mean very hot). I installed a little 24V PC blower into the sender box which is feeding the cool air from outside into the box.
Connected direct to the 24V input.
Works very well.
