Collecting pandas==2.0.1
Downloading pandas-2.0.1.tar.gz (5.3 MB)
|████████████████████████████████| 5.3 MB 1.6 MB/s
Installing build dependencies ... done
Getting requirements to build wheel ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/tmpwer13amc_in_process.py get_requires_for_build_wheel /tmp/tmp4ncd6enp
cwd: /tmp/pip-install-k9v_ulfi/pandas_d695f9094fe84122baf2079bceba82ab
Complete output (53 lines):
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/numpy/core/__init__.py", line 22, in <module>
from . import multiarray
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/numpy/core/multiarray.py", line 12, in <module>
from . import overrides
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/numpy/core/overrides.py", line 7, in <module>
from numpy.core._multiarray_umath import (
ImportError: libcblas.so.3: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/tmp/tmpwer13amc_in_process.py", line 280, in <module>
main()
File "/tmp/tmpwer13amc_in_process.py", line 263, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/tmp/tmpwer13amc_in_process.py", line 114, in get_requires_for_build_wheel
return hook(config_settings)
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 341, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 323, in _get_build_requires
self.run_setup()
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 487, in run_setup
super(_BuildMetaLegacyBackend,
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 338, in run_setup
exec(code, locals())
File "<string>", line 18, in <module>
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/numpy/__init__.py", line 140, in <module>
from . import core
File "/tmp/pip-build-env-1q7dn5om/overlay/lib/python3.9/site-packages/numpy/core/__init__.py", line 48, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.9 from "/usr/bin/python3"
* The NumPy version is: "1.19.3"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
