versuche eben den Ardumower Code Azurit 1.0a6 und der mitgelieferten IDE 1.0.6 und OpenSuse 13.2 zu prüfen und hochzuladen, erhalten aber folgende Fehler:
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Linux), Board: "Arduino Mega 2560 or Mega ADK"
In file included from mower.h:29,
from config.h:10,
from mega.cpp:39:
robot.h:194: error: ISO C++ forbids initialization of member ‘esp8266ConfigString’
robot.h:194: error: making ‘esp8266ConfigString’ static
robot.h:194: error: invalid in-class initialization of static data member of non-integral type ‘String’
Ich habe dann in robot.h folgendes abgeändert:
char esp8266Use; // use ESP8266 Wifi module?
//String esp8266ConfigString = "";
String esp8266ConfigString;
Allerdings kommen dann folgende Fehler beim 2. Durchlauf:
mini.cpp.o.bss.senSonarTurn+0x0): multiple definition of `senSonarTurn'
mega.cpp.o.bss.senSonarTurn+0x0): first defined here
/home/thomas/arduino-1.0.6/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
mower.cpp.o: In function `Mower::Mower()':
mower.cpp:134: multiple definition of `senSonarTurn'
pfod.cpp.o: In function `RemoteControl::initSerial(HardwareSerial*, unsigned long)':
pfod.cpp:47: multiple definition of `senSonarTurn'
robot.cpp.o: In function `Robot::Robot()':
robot.cpp:43: multiple definition of `senSonarTurn'
ardumower.cpp.o: In function `setup':
/home/thomas/arduino-1.0.6/ardumower.ino:48: multiple definition of `senSonarTurn'
Wire/Wire.cpp.o: In function `TwoWire::begin(int)':
/home/thomas/arduino-1.0.6/libraries/Wire/Wire.cpp:75: warning: internal error: out of range error
/home/thomas/arduino-1.0.6/libraries/Wire/Wire.cpp:76: warning: internal error: out of range error
core.a(HardwareSerial.cpp.o): In function `global constructors keyed to rx_buffer':
/home/thomas/arduino-1.0.6/hardware/arduino/cores/arduino/HardwareSerial.cpp:504: warning: internal error: out of range error
/home/thomas/arduino-1.0.6/hardware/arduino/cores/arduino/Print.h:43: warning: internal error: out of range error
/home/thomas/arduino-1.0.6/hardware/arduino/cores/arduino/Stream.h:53: warning: internal error: out of range error
core.a(main.cpp.o): In function `main':
/home/thomas/arduino-1.0.6/hardware/arduino/cores/arduino/main.cpp:44: warning: internal error: out of range error
Mache ich was falsch oder sind das bekannte Sachen im aktuellen Code?
Thomas
from config.h:10,
from mega.cpp:39:
Thomas
