Hello xjust,
I've tried to connect 2nd mow
motor to PCB 1.3 and I've failed. Did you succeed?
I've bought the components (4xBY500 diode, 1xMP3-Y2 10uF capacitor, 1x1.8R 2W METAL resistor) and soldered the board described in
https://forum.ardumower.de/threads/...s-on-pcb1-3-for-2-0-chassis.23553/#post-38669. I've tested it few times and it looks like it's soldered/connected as in the schema but I have no power on the new M1OUT1, M1OUT2 on my board. Maybe I'm missing something?
I've used P39/Res24V-1 to provide my board with VCC and GND. Is this correct?
Unfortunately, I've also failed to find JP3 which will probably activate M1OUT1, M1OUT2 on the driver for the second mow
motor. Can anybody point me where JP3 is located?
I haven't found any success story on the forum explaining how to connect the second
motor safely to the PCB 1.3 board. If you know some basic howto here or on the wiki page I'd be grateful!
Thanks in advance!
Best regards
Szymon
