Res.AD15 / Res.AD13 600Ohms
Checkout D66,D65, D69,D70. It could be, that the connection comes over GND or IOREF.
Solder out D66. If you measure 600 ohms again, solder out D65. If the problem exists, than the problem is maybe not the diode. Have you Diode Tester in you multimeter?
