emmanuel_tuloup@gmail_com
hello,
i've bought the gy-87:
GY-87 10DOF MPU6050 BMP180 HMC5883L capteur Arduino Raspberry Pi https://www.marotronics.de/GY-87-10DOF-MPU6050-BMP180-HMC5883L-Sensor-Arduino-Raspberry-Pi
but i wonder if it is the good one (the good one is it the "9-axis IMU sensor GY-801 L3G4200D-ADXL345-HMC5883L-BMP180" ?)
is the slot is I2C2 for these two IMU ?
the GY-87 have:
VCC_IN
3.3V
GND
SCL
SDA
FSYNC
INTA
DRDY
and the G-801 have:
VCC_IN
VCC_3.3V
GND
SCL
SDA
M_GRAY
A_INT1
A_INT2
G_INT2
G_INT1
so it seem's to be different things
so is there a good one to go into the PCB1.3 ?
an how to connect to I2C2 (there is just 5V GND 3.3V, and SDA and SDL, but no all the others)
is there other connectors on PCB1.3 than the I2C2 ?
thanks
the GY-87 have:
VCC_IN
3.3V
GND
SCL
SDA
FSYNC
INTA
DRDY
and the G-801 have:
VCC_IN
VCC_3.3V
GND
SCL
SDA
M_GRAY
A_INT1
A_INT2
G_INT2
G_INT1
thanks
