HC-05 Configuration
erick
Hi!
So I decided to take the control via bluetooth, but the problem is that my phone (Glaxy S4) doesn´t detect the HC05 module.
So I've been reading about that problem and many forums refer to the module configuration, so I decide to do it by myself with an arduino program (attached) and the module responses ok to the configuration. But still doesn´t work. I'm guessing that maybe is the Class, or the Baud Rate, I dont know, because the module seems to work properly but the phone don´t detect anything.
Anyone can help me? Thank you so much!
+------Info------+
+Role=0
+CMode=1
+BaudRate= 38400,0,0
+Class=0
The 4th step, because when I try to paired with the phone the phone doesn´t detect the bluetooth module, as if it was hidden, but the module seems to work right, actually I'm using an Arduino Uno w/ 9600 baud, the default settings for this hc05 module is 38400.
I tried both settings (9600 arduino - 9600 bluetooth) and (38400 arduino - 38400 bluetooth) but don't have luck...
