Gyro MPU 9250 unter Azurit
SefanH
Wie bringe ich dem Gyro das laufen unter Azurit bei?
Irgendwie wird der wohl gefunden, nur Daten werden keine geliefert...
In der Console sieht das so aus...
IMU: found calib data
accOfs=0.00,0.00,0.00
accScale=0.00,0.00,0.00
comOfs=0.00,0.00,0.00
comScale=0.00,0.00,0.00
initL3G4200D
gyro read error
gyro read error
gyro read error
loadSaveErrorCounters: read
loadSaveErrorCounters addrstop=423
loadUserSettings
loadSaveUserSettings addrstop=314
loadSaveRobotStats: read
loadSaveRobotStats addrstop=826
-------------------START-------------------
Ardumower 1.0a9-Azurit  PCB 1.3  Arduino Due  IOREF=3.30
Robot: Ardumower
press...
  d for menu
  v to change console output (sensor counters, values, perimeter etc.)
sen_counters
Sending ESP8266 Config
RTC datetime received: Sat 20.02.2021  23:04
IMU comm error
t     1 L  0 m0 OFF  rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 593.1 chg -167.-6 40.0 imu  0 adc  0 Ardumower
ERR_IMU_COMM
IMU comm error
IMU comm error
IMU comm error
IMU comm error
loadSaveRobotStats: write
t     0 L  0 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 84 Ardumower
IMU comm error
t     0 L  0 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc  0 Ardumower
IMU comm error
IMU comm error
IMU comm error
IMU comm error
IMU comm error
t     1 L5830 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 97 Ardumower
IMU comm error
IMU comm error
IMU comm error
IMU comm error
t     0 L6620 m0 CHARG rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 97 Ardumower
IMU comm error
t     0 L6620 m0 CHARG rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc  3 Ardumower
IMU comm error
IMU comm error
IMU comm error
IMU comm error
IMU comm error
t     1 L6920 m0 CHARG rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 97 Ardumower
IMU comm error
IMU comm error
IMU comm error
IMU comm error
t     0 L6827 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 93 Ardumower
IMU comm error
t     0 L6827 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc  0 Ardumower
ERR_IMU_COMM
IMU comm error
IMU comm error
IMU comm error
IMU comm error
IMU comm error
t     1 L6859 m0 STAT rpm    0    0 set    0    0 sen    0    0    0 bum    0    0 dro    0    0 son   0 yaw   0 pit   0 rol   0 bat 27.5 chg  8.8  0.0 imu  0 adc 93 Ardumower
IMU comm error
IMU comm error
IMU comm error
IMU comm error
Hast du in der Mower.h den Gy801 deaktiviert und den MPU 9250 aktiviert?
Und du musst Hardwareseitig noch eine Änderung vornehmen. Am Imu direkt muss man die Adresse ändern, sonst gibt es einen Konflikt mit dem RTC Modul.
A0 mit VCC (3,3V) verbinden.
Gesucht, gefunden... jedoch im Arduino-Master Code... Was ist denn mit der Version die man "normalerweise" laden sollte??? Ist die nicht weiter entwickelt worden? Lieber die Master-Version nehmen???
Hardwareseitig Adresse ändern ist gleich A0 mit VCC (3,3V) verbinden - Das hab ich doch richtig verstanden?!?
Gruß Stefan
Use the master version.
Branch one was only for test by deactivating compass.
A0 to VCC avoid I2C confict between IMU and RTC
Kann mir jemand bei dem Fehler weiterhelfen?
"C:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10813 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\sefan\\AppData\\Local\\Temp\\arduino_build_639961\\sketch\\perimeter.cpp" -o "C:\\Users\\sefan\\AppData\\Local\\Temp\\arduino_build_639961\\sketch\\perimeter.cpp.o"
In file included from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/sam3xa/include/sam3x8e.h:260:0,
                 from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/sam3xa/include/sam3xa.h:44,
                 from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/sam3.h:59,
                 from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/sam.h:198,
                 from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/libsam/chip.h:25,
                 from C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\cores\arduino/Arduino.h:42,
                 from C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.h:38,
                 from C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp:24:
C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\system/CMSIS/CMSIS/Include/core_cm3.h:868:46: error: expected ')' before '*' token
   #define MPU               ((MPU_Type       *)     MPU_BASE      )   /*!< Memory Protection Unit             */
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp:39:11: note: in expansion of macro 'MPU'
   MPU9250 MPU(MPU9250_ADDRESS_AD0_HIGH);
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'void IMU::initAccel()':
imu.cpp:258:9: error: request for member 'beginAccel' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.beginAccel(ACC_FULL_SCALE_8_G);
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'bool IMU::readAccel()':
imu.cpp:270:9: error: request for member 'accelUpdate' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.accelUpdate();
imu.cpp:281:19: error: request for member 'accelX' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float x = MPU.accelX();
imu.cpp:282:19: error: request for member 'accelY' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float y = MPU.accelY();
imu.cpp:283:20: error: request for member 'accelZ' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float z = -MPU.accelZ();
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'boolean IMU::initGyro()':
imu.cpp:345:9: error: request for member 'beginGyro' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.beginGyro(GYRO_FULL_SCALE_2000_DPS);
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'boolean IMU::readGyro()':
imu.cpp:379:9: error: request for member 'gyroUpdate' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.gyroUpdate();
imu.cpp:392:23: error: request for member 'gyroX' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
         gyro.x += MPU.gyroX();
imu.cpp:393:23: error: request for member 'gyroY' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
         gyro.y += MPU.gyroY();
imu.cpp:394:24: error: request for member 'gyroZ' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
         gyro.z += -MPU.gyroZ();
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'void IMU::initCom()':
imu.cpp:421:9: error: request for member 'beginMag' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.beginMag(MAG_MODE_CONTINUOUS_100HZ);
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'bool IMU::readCom()':
imu.cpp:437:9: error: request for member 'magUpdate' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.magUpdate();
imu.cpp:439:29: error: request for member 'magX' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float x = (int16_t) MPU.magX();
imu.cpp:440:29: error: request for member 'magY' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float y = (int16_t) MPU.magY();
imu.cpp:441:29: error: request for member 'magZ' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     float z = (int16_t) MPU.magZ();
C:\Users\sefan\AppData\Local\Temp\arduino_build_639961\sketch\imu.cpp: In member function 'bool IMU::hwInit()':
imu.cpp:767:9: error: request for member 'setWire' in '3758157200u', which is of pointer type 'MPU_Type*' (maybe you meant to use '->' ?)
     MPU.setWire(&Wire);
"C:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10813 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\sefan\\Documents\\ArduinoData\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\sefan\\AppData\\Local\\Temp\\arduino_build_639961\\sketch\\pfod.cpp" -o "C:\\Users\\sefan\\AppData\\Local\\Temp\\arduino_build_639961\\sketch\\pfod.cpp.o"
Bibliothek Wire in Version 1.0 im Ordner: C:\Users\sefan\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\libraries\Wire  wird verwendet
exit status 1
Nimm Mal bitte Arduino 1.6
Mit der 1.8 Version gibt es Probleme.
Vielleicht klappt es dort zu Compilen.
A0 am Imu direkt muss mit 3,3V verbunden werden
Edit:
Es liegt am Code, ich habe nie unter DUE versucht es zu compilieren, da ich einen Mega nutze. Ich schau mal drüber, ob ich den Fehler beheben kann.
ok, Fehler behoben, bei mir baut es jetzt unter dem Due.
Es gab einen Namenskonflikt mit einer DUE eigenen Bibliothek.
einmal den Master neu ziehen und probieren bitte.
Ich muss gucken wie ich es schaffe... Meine Frau dreht so langsam durch 🤪
Ardumower, Drohne, Wortuhr (im DIY Bereich), viel auf der Arbeit (täglich ca. 12 Stunden), Vesparoller, Arbeit als Kassenwart der Feuerwehr und von einem Förderverein... Das ist wie ein Ritt auf der Kanonenkugel... 😁
Nunja, so ist das Leben mit ADHS. Man muss halt alles machen was einem in den Sinn kommt!
Hab mir jetzt die Version 1.6.1 geladen und alles nochmals hochgeladen. Bei der Version friert mir jedoch die Konsole ein wenn ich das Menü aufrufen möchte. Außerdem ist mir grade der DC-DC Wandler angebrannt. Warum auch immer...
Bei Anschluss der Batterie piept der Summer auch dauerhaft. Erst nach trennen der Stromversorgung und nach ca 1-2 Sekunden später wieder anschließen funktionierte alles.
Nun muss ich erstmal Ersatzteile besorgen. Der LM2596s hat ein Loch an der Seite.
Welche Arduino IDE Version nutzt du denn genau? Was was schaltet der Notausschalter eigentlich ab?
Gestern hat die Konsole die Spannung nicht korrekt angezeigt. Abschaltung wegen zu geringer Spannung stand da dann. Ist dann der Gyro auch abgeschaltet?
Ich hab eine Brücke von AD0 zu VCC gezogen, die Adresse scheint nun anders zu sein. Werte konnte ich gestern trotzdem nicht bekommen.
Wie funktioniert das denn mit der Kalibrierung?
Die Konsole friert mir auch ein unter der 1.6.13. Bisher war ich immer unter Linux unterwegs, da ist das nicht passiert. Seit dem WE habe ich aber einen neuen Pc mit Windows 10. Ich habe leider noch nicht raus gefunden, woran das liegt.
Die Brücke hast du direkt am IMU gezogen?
Welche Brücke wo am IMU? Und warum? Wofür steht ADO? Fragen über Fragen......
Habe ein ähnliches Problem, benutze allerdings die AZURITBER.
Gruß UWE
Direkt am IMU MPU9255 von A0 auf 3,3V, damit der IMU seine Adresse ändert. Sonst kommt es zum Adresskonflikt mit dem RTC.
auch bei AZURITBER kommt es sonst Konflikt auf dem I2C Bus. A0 ist ein Eingang des Mikrocontrollers am IMU.
Nicht dem A0 vom Arduino verwechseln!!
Also den ADO auf 3,3V auf dem MPU(rotes Versorgungskabel von VCC auf ADO?)?
Danke schön einmal für die Antwort.
Gruß Uwe
It's possible to connect MPU 9250 by 2 ways (Power with 5V or 3.3V)
For 5V see sunray wiki :
Ardumower Sunray - www.wiki.ardumower.de
For 3.3V:
IMU <-->PCB1.3
VCC <---> 3.3V
GND<---> GND
SCL <--->SCL
SDA <--->SDA
ADO <-> VCC on IMU
Optionaly you can shunt the DC/DC converter locate in the imu with a solder join (see picture green circle)
Do not forget JC2 to 3.3V.
